Author: Subject: Any experience of POR-15
r1_pete
posted on 18/2/08 at 07:17 PM Reply With Quote
As per title, anyone with experience of por-15, how well does it last, application - brush or spray gun.
I'm refinishing the underside of the MG and want body colour, but some protection, will be applied on a mixture of new and previously painted panels.
Cheers.
Pete.
SALAD
posted on 18/2/08 at 07:25 PM Reply With Quote
It's hardcore. I'm not on the road yet but after bashing some sharp edged panels into my chassis a good few times, accidently ofcourse, the POR15 'chassis coat black' top coat chipped off but the POR15 rust preventative paint (grey stuff) underneath has no damage at all.
I would say if I didn't leave so long between undercoating and applying the chassis coat black then it would be 'as one' and not chip at all.
It's all about good prep.
JohnN
posted on 18/2/08 at 07:55 PM Reply With Quote
It says on the packaging, "don't get it on your hands, only time will remove it"
I can vouch for that.
Other than that I've used it to protect exposed underbody on a similar restoration, and I've every confidence in it.
2b_pablo
posted on 18/2/08 at 08:08 PM Reply With Quote
also lol! good stuff
if it aint broke... pull it off and upgrade it!
posted on 18/2/08 at 08:19 PM Reply With Quote
Top stuff - I used it for my roll bar.
A few things to remember - it doesn't stick well to shiny or smooth steel - ideally it should be painted over a surface that used to be a bit rusty but then wire-brushed. Alternatively, use their Metal Ready preparation to get the surface ready - it cleans off any rust, etches the surface and leaves a zinc phosphate coating. It ends up feeling like very fine emery paper.
Also, it's no good as a top coat on anything that'll be exposed to sunshine - it doesn't fall off, but it will discolour. I lightly rubbed mine down and sprayed it with Plastikote. The top coat has chipped off in a few places, but the POR-15 still remains.
Mine was brushed on - when you put on a coat it looks all lumpy and streaky, but it dries rapidly to a smooth surface.
Not cheap, especially if you use the Metal Ready as well, but it does do what it says on the tin.
HTH
COREdevelopments
posted on 18/2/08 at 10:43 PM Reply With Quote
where the best place to get it?
rob
SALAD
posted on 18/2/08 at 10:49 PM Reply With Quote
I got mine from here....
http://www.frost.co.uk/productList.asp?catID=24&frostCat=Painting&subcatID=37&frostSubCat=POR%2D15
and they were very good on delivery.
