Author: Subject: Blank aluminium cortina hubs
Jeffers_S13
posted on 20/2/08 at 01:17 PM Reply With Quote
Does anyone know where I can get blank aluminium Cortina hubs from ?
I want to run wheels with a different PCD and ideally not have an extra set of holes.
James
edit : and while were on it, can I get blank rear hubs aswell ???
[Edited on 20/2/08 by Jeffers_S13]
posted on 20/2/08 at 01:23 PM Reply With Quote
look here
one of the companies does 5 hole hubs so I guess if you speak to them, they should be able to drill to your PCD, or supply undrilled.
Richard Quinn
posted on 20/2/08 at 01:52 PM Reply With Quote
Originally posted by Jeffers_S13
edit : and while were on it, can I get black rear hubs aswell ???
Absolutely...
Image deleted by owner
Sorry, couldn't resist it!!
RazMan
posted on 20/2/08 at 03:49 PM Reply With Quote
If you mean black anodised rear hubs, you won't find any in anything but steel. The splines would just strip if they were alloy ...... so I guess the Smoothrite is the best option.
Raz
Jeffers_S13
posted on 20/2/08 at 04:02 PM Reply With Quote
Haha ! sorry, no I mean 'blank', not necessarily alloy, I want a different PCD on the back aswell.
I am most likely going to accomodate the different PCD with an adapter/spacer, but a new hub would be the nicest solution.
Build pics : http://tinyurl.com/fuyh6
