Author: Subject: Polishing Aluminium
ChrisS
posted on 24/2/08 at 03:40 PM Reply With Quote
Polishing Aluminium
Im trying to clean up the aluminium bonnet and side panels ive made for the car, and tbh im having a nightmare. Ive wet and dry sanded with very fine to get out some small scratches, and now im trying to polish it shiny with autosol.
I just can seem to get a consistent finish. It seems to go dark after buffing off autosol, and ive tried some other stuff, and now i almost wish i hadnt started trying.
Any ideas how to get it nice.
posted on 24/2/08 at 03:45 PM Reply With Quote
One tip that came from this site...
Polish away until the surface is nice and shiny. Get a clean cloth, dip it into some flour (plain or self-raising!) and rub that over the top.
You'll find that all the old polish is lifted off and the surface is left nice and shiny.
Well - it works for me, anyway!
Confused but excited.
posted on 24/2/08 at 03:53 PM Reply With Quote
Autosol recommend their finer polish for a high degree of finish on aluminium, not the 'normal' Autosol.
I just found that out after using ordinary Autosol for forty odd years.
posted on 24/2/08 at 04:01 PM Reply With Quote
Oh - nearly forgot - Meguiars Metal Polysh is very effective, and much easier to clean off. Quite expensive, but my little tub has lasted a couple of years and nowhere near empty yet. Odd smell though!
You can get it in Halfords.
[Edited on 24/2/08 by David Jenkins]
r1_pete
posted on 24/2/08 at 04:05 PM Reply With Quote
On the polished cases on my 72 suzuki, I use some stuff called belgom alu, not only polishes but leaves a protective residue behind.
Rgds.
Pete.
r1_pete
posted on 24/2/08 at 04:08 PM Reply With Quote
here you go, a pic of the results....
eccsmk
posted on 24/2/08 at 04:38 PM Reply With Quote
http://i4detailing.co.uk/acatalog/Metal_Polish_Sealant.html
try this stuff i was told about it on detailing world
atb
[Edited on 24/2/08 by eccsmk]
martin1973
posted on 24/2/08 at 04:59 PM Reply With Quote
this works on most thing but never tried a bonnet?
using 2000 grit wet and dry with autosol,using the autosol as the lube.
works wonders on alloy caseing and rocker boxes.
otherwise i used t-cut on my alloy side panels nearly a mirror finish?
martin
IDONTBELEIVEIT
posted on 24/2/08 at 05:05 PM Reply With Quote
the tip that dave gave is a good one,but the proper stuff is called hydrogenated lime a very fine powder that removes polish after polishing(does that make sense)ready for (buffing) after polishing
wayno!!
Are We There Yet, Are We There Yet!!!!
ALEXARAS
posted on 27/2/08 at 04:24 PM Reply With Quote
Is anyones using Brasso?
What do you think of it?
Locost 7 RS2000
Beach Buggy Rotary
posted on 27/2/08 at 07:17 PM Reply With Quote
After trying loads of different types of polish I now use Meguires , easier to use and gives a good shine. Tried the flour trick , works OK
johnjulie
posted on 29/2/08 at 09:41 PM Reply With Quote
Get some Belgom Ulu. About £7.00 from Ebay. Brilliant stuff, easy to use, flows easily, gives an excellent shine.
You'll like it!
Cheers John
JFDI
"Just F*****G Do It"
Trev D
posted on 29/2/08 at 10:35 PM Reply With Quote
Hi, I have used alumagic hard work gives good results and leaves a protective coating on the ali and I have also used a polish called mothers which is excellent for giving instant shine not so good for taking out scratches, as the alumagic is. I have also found if you try and polish a local area it will never look an even finish so you will have to go over the whole panel.
ATB and happy polishing Trev
