matt.c
posted on 28/2/08 at 11:21 PM |
HOW LOW IS YOURS.........
Can you BEC guys please tell me how low or how close to the ground is your sump?
tom windmill
posted on 28/2/08 at 11:23 PM |
we usually aim for around 4" clearance with ours...
Cheers Tom
bigrich
posted on 28/2/08 at 11:27 PM |
same as Tom said about 100mm or so
graememk
posted on 28/2/08 at 11:28 PM |
best not look under my car
snapper
posted on 28/2/08 at 11:29 PM |
What engine are you running and have you fitted a shortened sump?
The ideal is to have the now shortened sump level with the bottom of the bellhousing.
If your sump is a bit low then a strong sump guard at least is worth concidering, only problem with a low sump guard is that when you bottom out, for
you will, you will have no steering and no brakes
Oops didn't read the BEC bit, 4 inches it is then.... i'll get my coat..... and stop drinking the beer.
[Edited on 28/2/08 by snapper]
I eat to survive
I drink to forget
tomblyth
posted on 29/2/08 at 05:47 AM |
inch lower than the chassis rails I'll tell you if it ever hits the ground!
smart51
posted on 29/2/08 at 08:03 AM |
My chassis rails are 100mm from the ground. The sump is about 25mm lower, though I've never measured it. It goes over speed bumps but I do
slow down for them.
posted on 29/2/08 at 08:10 AM |
I've got 85-90mm ground to sump clearance. No problems so far but I do slow down a fair bit for speed bumps...... Obviously how far forward /
back the lowest point is effects things- if its near the front axle you'll have fewer clearance problems (for a given sump clearance) than if
the lowest sump point is right next to the firewall....
nitram38
posted on 29/2/08 at 08:40 AM |
On the motaleira, my R1 sump is level with the underside of two rails. I will also be fitting a skid plate over it, fitted to the rails.
Fortunately I have added protection in the form of Air adjustable suspension.
I can either drop the car to ground level when parked (helps getting in and out) or raise it to 150mm clearance for speedbumps, at the flick of a
switch.
The car will be set up to run at 75mm during normal driving.
richard thomas
posted on 29/2/08 at 07:19 PM |
'bout 4 fingers.....
mackei23b
posted on 29/2/08 at 08:44 PM |
I have a feeling my Indy with a ZX9R is about the same.
Ian
slow down for them.
ChrisS
posted on 29/2/08 at 09:34 PM |
Ive fitted my R1 with the sump level with the bottom rail so it doesnt stick out at all, and then i have about 125mm clearance to the ground at the
front and 135mm at the rea, although thats not necesarily final until its on the road and i setup the suspension. It looks about right tho.
matt.c
posted on 29/2/08 at 09:59 PM |
Hmm? Are you using the standard zx9r sump? Mine sits about 2 inches from the floor!!!!!!! How come your sits so much higher than mine? Can you
post some pics of you engine bay and sump please.
matt
Ian
slow down for them.
mackei23b
posted on 10/3/08 at 03:30 PM |
Hi Matt
I can re-measure it. However I did make up my own cradle for the Indy.
Ian
matt
Ian
slow down for them.
