Author: Subject: fibreglass help please
eccsmk
posted on 2/3/08 at 10:35 PM Reply With Quote
im repairing a bonnet and keep getting air trapped in the edges of the bonnet scoop meaning lots and lots of sanding
any fibreglass experts online??
thank you in advance folks
twybrow
posted on 2/3/08 at 10:55 PM Reply With Quote
What technique are you using? You should be working it in with a paintbrush, in a kinda dabbing motion (stippleing). Dont be tempted to flood it with resin, just use as much as you can get away with, whilst not leaving any dry spots.
eccsmk
posted on 2/3/08 at 11:02 PM Reply With Quote
yeah using paint brush to push the air away to the edge of the glass but it just slowly fill a pocket of air again. i'll have another bash tomorrow night
cheers for the help
[Edited on 2/3/08 by eccsmk]
nitram38
posted on 2/3/08 at 11:09 PM Reply With Quote
As the fibre resin is starting to cure, use a metal roller (available from fibreglass suppliers) to push the air to the edges.
owelly
posted on 2/3/08 at 11:13 PM Reply With Quote
or you could be using too much catty (hardener) so the resin is getting warm and the air is expanding as it's curing.
http://www.ppcmag.co.uk
eccsmk
posted on 2/3/08 at 11:29 PM Reply With Quote
i'll have a play tomorrow night thanks folks
mixing 20ml catalist to 1kg of resin so should be ok
ill pop round and pick up a new roller tomorrow too
again thank you
Chippy
posted on 2/3/08 at 11:40 PM Reply With Quote
If you are trying to make the GRP go round/over a sharp edge you may never be able to stop the air from getting in. GRP does not like sharp corners, needs to be nicely rounded. HTH Ray
trextr7monkey
posted on 3/3/08 at 12:25 AM Reply With Quote
http://www.ecfibreglasssupplies.co.uk/store/
If youare still stuck phone these guys - it is their business and they are very good. Also very competitive on price for raw materials.
hth
Mike
Mr Whippy
posted on 3/3/08 at 02:17 AM Reply With Quote
or use P40 for bit like that, great stuff and can be used in any problem areas, it's also very strong. Rescued attachment isoponp40range.jpg
Delinquent
posted on 3/3/08 at 10:43 AM Reply With Quote
Does sound rather like you are trying to mould the glass over a shape it cannot conform to. If possible you could rig up either a vacuum or pressure application to get over the problem - something as simple as a dustbin liner filled with sand can do wonders! Needs to be quite thin plastic and a lot of sand.
A bit of a bodged version of the professional vac forming
eccsmk
posted on 3/3/08 at 11:18 AM Reply With Quote
thanks folks
finished it just now in my erm lunch break
i used some loose glass (chopped off ends) to smooth out the sharpe edge then added 4 layers of 2oz to strengthen up around the scoop
when i get back on stturday ill pop up some pictures
thanks again
[Edited on 3/3/08 by eccsmk]
RazMan
posted on 3/3/08 at 11:22 AM Reply With Quote
As Whippy says, using a little chopped strand P40 in the troublesome areas can stop air pockets forming. The normal matting will not like going round sharp corners so the P40 will fill the voids nicely and keep the joint strong.
Raz
eccsmk
posted on 3/3/08 at 11:31 AM Reply With Quote
i'll see how it looks later in week should be ok now
i'll even put my camera on charge now so i dont forget later
thank you
