Author: Subject: connecting a coarse to a fine thread
jabbahutt
posted on 4/3/08 at 02:16 PM Reply With Quote
Afternoon all
need a solution to a problem. I'm trying to connect something with a coarse female thread to something with a fine male thread.
Basically I'm trying to use some shower hose to fit to the bottom of my headlights to run the cable in as I think it'll look tidy and be in keeping with the car having chrome wishbones etc.
I know trivial and unimportant but seeing I've spent so much time on the rest of the car I thought it would be worthwhile.
Any ideas much appreciated
Nigel
[Edited on 4/3/08 by jabbahutt]
nitram38
posted on 4/3/08 at 02:25 PM Reply With Quote
You will need some form of threaded adapter made up.
caber
Bigger spanner?
Caber
Humbug
posted on 4/3/08 at 02:26 PM Reply With Quote
glue or sealant?
jabbahutt
posted on 4/3/08 at 02:33 PM Reply With Quote
I don't suppose for any reason adaptors with a coarse thread at one end and a fine at the other are used for anything in plumbing etc as if they're available off the shelf it would be so much easier.
Cheers for the assistance.
Nigel
tegwin
posted on 4/3/08 at 02:37 PM Reply With Quote
Try dropping into your local hydraulic manufacturor...(or pirtek)sp? They have a fair few adapters..
But as its not a critical part I would be inclined to come up with a less costly and complex solution...
www.verticalhorizonsmedia.tv
pewe
posted on 4/3/08 at 02:56 PM Reply With Quote
Plastic metal onto the female thread with a bit of cling-film or ptfe tape on the male thread to stop it sticking?
Cheers, Pewe
Mr Whippy
posted on 4/3/08 at 04:33 PM Reply With Quote
grind off most of the coarse thread, bit of loctite or epoxy ,screw it up and it'll never come out.
[Edited on 4/3/08 by Mr Whippy]
matt_claydon
posted on 4/3/08 at 04:50 PM Reply With Quote
That's the kind of approach I'd take. It doesn't need to be a strong fixing, just not come apart.
907
posted on 4/3/08 at 04:56 PM Reply With Quote
1/2" BSP radiator bleed screw housing. (from plumbers, in brass or steel)
Remove the square headed pin and drill and tap the housing to suit the other thread.
Paul G
[Edited on 4/3/08 by 907]
907
posted on 4/3/08 at 04:57 PM Reply With Quote
