Author: Subject: Bonnet ventilation
Jos Fury
posted on 28/3/08 at 12:04 PM Reply With Quote
Bonnet ventilation
Hello,
Maybe another newbie question for youse guys but using the search option I could not find anything appropriate. ( maybe due to my english I did not use the right words for the search )
Well to get some hot air out from under the bonnet, especially from the exhaust side I am looking for a neat solution to solve this. Could make some nice holes and than ? Just put some mesh behind them and how.
Some pics would be nice if possible of course.
Thanks again
Jos
posted on 28/3/08 at 12:08 PM Reply With Quote
One option is to use the STM (now Aries) bonnet- they have vents in the sides near the back as standard.
Otherwise a Caterinvan vented bonnet's a good option (if it will fit).
You can also either make some louvres (if your bonnet is ali) or buy GRP vents that you can stick in place...
posted on 28/3/08 at 12:09 PM Reply With Quote
posted on 28/3/08 at 12:11 PM Reply With Quote
Heres ours;
[img][/img]
Mr Whippy
posted on 28/3/08 at 12:13 PM Reply With Quote
Personally I like the round holes and other shapes with the mesh behind, suits the car style well.
posted on 28/3/08 at 12:19 PM Reply With Quote
Car builder solutions do quite a few....
http://www.cbsonline.co.uk/body-vents-and-scoops-112-c.asp
They even do ones with side-repeaters...
neilj37
posted on 28/3/08 at 12:27 PM Reply With Quote
I added a vent to the nose cone which has helped reduce the under bonnet temps:
Mr Whippy
posted on 28/3/08 at 01:02 PM Reply With Quote
never even noticed that Car builders were now doing online ordering. A sad day for my card
Humbug
posted on 28/3/08 at 01:25 PM Reply With Quote
I put ali louvre vents in the rear sides of the ali bonnet - similar position to the ST/Aries ones
mark chandler
posted on 28/3/08 at 01:42 PM Reply With Quote
Old school, louves in ali bonnet
Made a simple stamper from scrap, cut slots and bashed them in so proper locost = free
posted on 28/3/08 at 01:51 PM Reply With Quote
make a hole and bolt/rivet on some aluminium louvre panel from B&Q.
carb view
carb view
Mr Whippy
posted on 28/3/08 at 02:01 PM Reply With Quote
quite impressed with that, nice job
stevec
posted on 28/3/08 at 02:37 PM Reply With Quote
Rover ones.
Steve.
lotustwincam
posted on 28/3/08 at 07:34 PM Reply With Quote
Jos Fury
posted on 28/3/08 at 08:33 PM Reply With Quote
thanx !
quite some options to choose from and some very nice ones. I like the diversity too
well, I got myself some stainless mesh at work and found some alu black "standard racing mesh" in the shed so lets think something out. like to have some bonnet ventilation on top of the bonnet. just in front of the window, but a lot of water will find its way ( got my coil pack there somewhere ).
think I will go for three ventilation slots left and right, each side of the bonnet. its grp so i can simplu make some nice slots and put the mesch behind, but maybe it can be done a bit better. since the color of my car is yelloww:
I can have some aluminium lasercutted or stainless but want to keep it low profile.
mmm... how to go ahead.
( because of the colour even thought about putting a chiquita banana sticker on the back )
@neilj37, what did you do to get the holes so nicely finished ? some kind of "piping"?
( do not know what this is called )
cheers
jos
[Edited on 28/3/08 by Jos Fury]
zetec
posted on 29/3/08 at 08:00 AM Reply With Quote
More of the same..
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
scutter
posted on 29/3/08 at 08:48 PM Reply With Quote
Here's mine, stamped by kool lourves. Cost half of Uncle Ron's budget
ATB Dan.
bonnet pic
bonnet pic
Jos Fury
posted on 30/3/08 at 09:04 AM Reply With Quote
Tanks again.
I like the louvres too, but my bonnet is not aluminium unfortunately. think I'm gonna keep it simple and just go zetecs way or alike. How to fix the mesh ? For the nose I used what we cal "kit" and a few very thin tyraps.
( hellfires louvres are great too )
did not know of the http://www.cbsonline.co.uk site. nice site.
posted on 30/3/08 at 09:15 AM Reply With Quote
Just use PU Adhesive to bond the mesh to the underside of the fibreglass.
Phil
Jos Fury
posted on 31/3/08 at 08:47 AM Reply With Quote
ok ! thanx.
