se7ensport
| posted on 8/4/08 at 12:35 PM |
Female M6 bolts needed
i'm looking for the female equivalent of a M6x10 bolt, would look a bit like a rivnut but with a domed hex head, I just can't kind them as
I don't know what they are called.
Any pointers?
Mr Whippy
| posted on 8/4/08 at 12:39 PM |
reminds me of the things used to screw cabinets together, these things?
http://www.diy.com/sl/home-improvement/106921744-it-solutions-cabinet-connector-bolts-pack-of-20.html
[Edited on 8/4/08 by Mr Whippy]
se7ensport
| posted on 8/4/08 at 12:45 PM |
Thanks Mr Whippy, now if they were 10mm long and stainless they would be idea.
I figure they must exist....
ReMan
| posted on 8/4/08 at 01:05 PM |
I love them.
Search for stainless flange button screw
worX
| posted on 8/4/08 at 01:16 PM |
A Female Flange...
... on locostbuilders???
You'll have Da Management comin' after you
quote: Originally posted by ReMan
I love them.
se7ensport
| posted on 8/4/08 at 01:32 PM |
I love them.
I've tried searching for them but only finding the male equivalent.
ReMan
| posted on 8/4/08 at 01:42 PM |
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=310028763073
Are these not want you want?
Bear in mind that the female version of a bolt is a nut
Mr Whippy
| posted on 8/4/08 at 01:54 PM |
their used to hold the walls of toilet cubical together
Delinquent
| posted on 8/4/08 at 02:12 PM |
You're looking for Long Nuts - try somewhere like Titan Fastners.
se7ensport
...Bear in mind that the female version of a bolt is a nut
except when its not....
it would look just like a button head bolt, but the thread is on the inside as per Mr Whippy's pic above. I think I may have come across them in
the past on bike brake leavers as it has a smooth outside for the lever to pivot on.
The long nut search has sort of paid off in that I've now got a better image, unfortunatley the one I've found it plastic.
[Edited on 8/4/08 by se7ensport]
RichardK
| posted on 8/4/08 at 02:27 PM |
Think I've seen similar on mini motos that hold the fairing on, through the frame and the flage head screw on the outside. Maybe worth a
search
Regards
Rich
Gallery updated 11/01/2011
Delinquent
| posted on 8/4/08 at 02:38 PM |
If you cant find exactly what you are after, in the past I've just used 2 dome hex head stainless bolts with a length of studding connector in
the middle, leaves you with the same lack of thread sticking out anywhere but means you can source it easily!!! (can definitely get M6 studding
connector in SS, then you just need a couple of 5mm long button head SS bolts
vinny1275
I had some (they were probably M6 as well), but I used them fitting the door handle to my garage door, as it's apparently made of
cardboard...... they came with the door handle iirc..
Good luck searching for long nuts btw....
Vince
| posted on 8/4/08 at 02:42 PM |
interscrews. (or possibly socket nut)
biggest size I've found is M5 in stainless.
se7ensport
| posted on 8/4/08 at 03:36 PM |
do you have a link?
| posted on 8/4/08 at 04:11 PM |
think it was these: http://www.nuts4bolts.com/di/41680
in A2 stanless.
some more; M6 too! in stainless.
http://212.69.200.177/Pages/2007%20yachtwindows.pdf
[Edited on 8/4/08 by 02GF74]
omega 24 v6
| posted on 8/4/08 at 04:57 PM |
At work we call them camtainers. I'll see if I can find out who makes them tommorrow.
Syd Bridge
| posted on 9/4/08 at 09:32 AM |
Commonly called 'Sleeve Nuts' in some parts of the world.
