Author: Subject: Bonnet catches and vents
adithorp
posted on 20/4/08 at 12:31 PM Reply With Quote
I started fitting the bonnet catches (amongst other stuff) to my Fury yesterday.
I'm using Aerocatches. I've got one at the back lower corner and was
thinking of some form of locating pin just behind the wheel arch to
firm things up. I'm now thinking of another Aerocatch instead and then
cut a vent hole the same size and shape (with black grill) in between.
What do you think? What does SVA man think of grills/expanded mesh?
adrian
RazMan
posted on 20/4/08 at 12:38 PM Reply With Quote
Mr SVA loves Aerocatches so you could use them for all sorts of panel fixings without any problems.
Grilles made from expanded mesh are fine unless they have huge holes in them (enough to trap a finger for example)
Raz
Miks15
posted on 20/4/08 at 12:44 PM Reply With Quote
why not put the catches in then put the mesh in post SVA to save any problems that may occur?
