Author: Subject: Velcro interior panels on?
RK
posted on 20/4/08 at 03:26 PM Reply With Quote
Does this leave them rattling about when driving? Otherwise, I'll glue or rivet as usual.
Sorry wrong forum. Should've gone in the one below!
[Edited on 20/4/08 by RK]
Mix
posted on 20/4/08 at 05:00 PM Reply With Quote
If there is no sructural requirement then velcro is actually beneficial, there is no tendancy to chafe or rattle and the panel is easily removed for access. Trim panels have been retained on aircraft this way for years.
Mick
RazMan
posted on 20/4/08 at 05:35 PM Reply With Quote
Just don't rely on the self adhesive Velcro - really sticky at first but the first sign of a warm day and everything drops off!
Raz
Mix
posted on 20/4/08 at 05:49 PM Reply With Quote
There speaks the voice of experience
Good surface preparation will minimise the risk of it debonding but in the presence of oil etc you may find the velcro to velcro bond is stronger than the velcro to chassis. Still it's easy to replace.
Mick
RazMan
posted on 20/4/08 at 09:35 PM Reply With Quote
I think it is more that the glue just goes runny when hot - it has happened to me a few times despite thorough cleaning with alcohol
Raz
RK
posted on 21/4/08 at 03:29 AM Reply With Quote
Hadn't thought of the heat/glue problem. Also, can anyone recommend a particular glue then? Also for vinyl/naugahide to alu. I'm using that on the tunnel top cover - I decided I wanted something to rest my arm on!
RazMan
posted on 21/4/08 at 06:35 AM Reply With Quote
I found that good old Evo-stik was the best stuff - and not the namby-pamby solvent free stuff either
Raz
