big_wasa
| posted on 7/7/08 at 08:57 PM |
The hardest job so far
About 12hrs work so far to fit the N/s side pannel and its still not finished.
I dont want to bugger them as I dont know if I can get replacments
How tight a fit have others found the Gts sides to be ?
big_wasa
| posted on 7/7/08 at 08:58 PM |
pic2
Jackman
posted on 7/7/08 at 09:42 PM |
Yes i have GTS panels for mine and the sides are tight fit. The back panel also needs a little pushng and pulling to get it on.When all the panels are
on and bolted down the fit is very good though.
Macbeast
| posted on 8/7/08 at 03:21 AM |
Very tight. I used a couple of paint scrapers on the bottom edge to spring back the return and a rubber mallet (gently) to persuade it on.
But fit is good and I don't think it's coming off in a hurry
flak monkey
| posted on 8/7/08 at 06:35 AM |
Yep very tight, and its by far the most difficult job of the build. Took 3 days to do both of my panels, 2 for the first one and only 1 day for the
second
Sera
http://www.motosera.com
scoop
| posted on 8/7/08 at 08:50 AM |
Slow and easy mate. They look very good though
Jackman
| posted on 9/7/08 at 06:29 PM |
Forgot to say you are doing a good job there but you are right if you bugger them up you will never get hold of Darren for replacement ones.
