<<  1    2    3  >>
Author: Subject: I fancy a new challenge - Supercharging
flak monkey
posted on 16/9/08 at 01:32 PM Reply With Quote
Having just bought a supercharged mini, I am thinking of something to do on those cold winter nights....
Not sure if anyone else has done it, but I think its worth a go.
Cossie engine, supercharger, fuel injection (mega squirt), see where I am going with this?
I love the pinto power and torque, but I want something to do as a challenge more than anything, just to say I have done it!
I think cossie as it already has the lowered compression ratio needed for forced induction. Unless anyone else has any bright ideas?
Other thing, the engine needs to be cheap to start with. Anyone got a 16v turbo cossie lump (minus the turbo!)sitting around that I could purchase?
Either that or I could supercharge the existing pinto... Would save me having to buy a new exhaust etc too.
[Edited on 16/9/08 by flak monkey]
Sera
http://www.motosera.com
Duncan_P
posted on 16/9/08 at 01:41 PM Reply With Quote
Not sure that a cossie engine will be that cheap, and getting hold of an un-abused one will also be tricky.
As an alternative how about going using a Saab turbo engine as a base? Some of them (can't remember what years off hand) come with a Vauxhall gearbox bolt pattern....so an off the shelf adaptor might fit your Type 9(?). A bit of a faff i know but would probably end up cheaper than a cossie lump. Also the 'stock' internals are allegedly stronger.
ETA: Actually thinking about it once you have added a custom exhaust im not sure how much cheaper the saab option would be
[Edited on 16/9/08 by Duncan_P]
tegwin
posted on 16/9/08 at 01:48 PM Reply With Quote
Why not get a zetec...1.8 or 2.0.... They can be had for so little money if you know where to look....Now one of those with a SC and megasquirt would shift!
www.verticalhorizonsmedia.tv
flak monkey
posted on 16/9/08 at 01:49 PM Reply With Quote
Lowering the CR is a bit of a bugger...but doable with some shims.
Its an option, certainly. Would go duratec if it had to be a modern ford engine though I think...
In all honesty, keeping the pinto is a good option as I wouldnt need to buy a new exhaust etc. Not sure if the cossie bolt pattern etc is the same, i presume it isnt.
Sera
tegwin
posted on 16/9/08 at 01:55 PM Reply With Quote
Failing that...
How about a VAG 1.8T unit?...
Perhaps slightly heavier than the zetec...But rock solid)
There are some nutters who have got around 350Hp out of fairly standard tune.....
Whack a SC on that and its almost ready to go... And im sure someone on here was selling VAG to MT75/T9 converters...
I always fancied getting one of the newer 1.6 duratec engines from the Sport KA, sticking a SC on that and sticking it in a middy.....not sure why
[Edited on 16/9/08 by tegwin]
mr henderson
posted on 16/9/08 at 02:01 PM Reply With Quote
Failing that...
With a bigger turbo and some changes to the ECU, not do-able with a supercharger though, I shouldn't think.
The power losses caused by a crank drived supercharger are considerable, so going from turbo to super seems like a step in the wrong direction.
John
Mr Whippy
posted on 16/9/08 at 02:08 PM Reply With Quote
what about a small jet engine? that looks fun
tegwin
posted on 16/9/08 at 02:09 PM Reply With Quote
Edited to say... Are you suggesting that he builds a jet engine, or uses one to provide scary amounts of boost for his piston engine?
Haha..yes...as soon as I can afford that tig welder I will be making myself a Gas turbine engine out of the largest truck turbocharger I can lay my hands on
flak monkey
posted on 16/9/08 at 02:19 PM Reply With Quote
John
I disagree, almost entirely with that statement, but then I would, wouldnt I?
Superchargers have far more advantages than a turbo, but their integration is more expensive and complex, therefore most production cars with forced induction use a turbo, not a SC.
There's a reason the most powerful vehicles use superchargers, not turbos. Yes they draw a lot from the crank, but they give you huge gains too, right through the rev range with very little lag.
Besides turbos pretty common in sevens these days, don't recall ever seeing one with a SC strapped on?
Sera
posted on 16/9/08 at 02:39 PM Reply With Quote
Go supercharger!!!
Only question is which engine.....
You want something strong, low CR, easily accesible crank pulley and sensible cams..
How about Volve engines??? They are certainly over-spec'd (look at how much abuse you can chuck at a Volvo rear axle before it'll complain)...
posted on 16/9/08 at 02:43 PM Reply With Quote
Only problem might be CR-
http://cgi.ebay.co.uk/1994-VOLVO-850-2-5-DOHC-ENGINE-GEARBOX-B5252S_W0QQitemZ270268353742QQcmdZViewItem?hash=item270268353742&_trkparms=72%3A984|3 9%3A1|66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14
has is RWD to begin...
but has a CR of 10.3:1 which will limit your boost potential unless you fit a decompression plate (or unless it's got a split block in which case you can use a spacer gasket).
flak monkey
posted on 16/9/08 at 02:46 PM Reply With Quote
Originally posted by BenB
Go supercharger!!!
All of those things are part of the reason my first thought was cossie engine. Not looking at silly boost, probably 1bar (14psi).
Volvo engines are solid, but I know bugger all about them, and I have a feeling an exhaust is going to be major money.....
Sera
owelly
posted on 16/9/08 at 02:55 PM Reply With Quote
You need to speak to the guys at PPC magazine as they have just done a series of articles on super charging. It gave a list of chargers, pully sizes and everything!
If you need a set of photocopies/scans, let me know!
http://www.ppcmag.co.uk
graememk
posted on 16/9/08 at 03:01 PM Reply With Quote
why dont you stick a bike engine in it ?
or
turbo the pinto, just for a laugh.
[Edited on 16/9/08 by graememk]
mr henderson
posted on 16/9/08 at 03:06 PM Reply With Quote
Are you referring to american dragsters? The Veyron uses turbos
So it's alright strapping what is in effect a large brake to an engine? I though the idea was to get more power, not waste it.
Turbos get most of their driving power from the heat energy in the exhaust, which otherwise would be wasted
John
x_flow57
posted on 16/9/08 at 03:11 PM Reply With Quote
Friend of mine has had a Cossie head put on his Pinto, with twin 50 Webbers it is putting out in the reigion of 300HP in his Mk1 Escort rally car. I think he has used his original Pinto ex manifold. Brian Randle in Suffolk did the machining worth a call if you want to go down that route.
Nick
flak monkey
posted on 16/9/08 at 03:30 PM Reply With Quote
Nick
Thanks Nick, good to know of a local engineering place
John,
I am referring to dragcars (not necessarily the US ones), both the top fuelers and the pro stock.
The veyron isn't that much of a feat of engineering, just an overpriced supercar IMO.
Sera
alistairolsen
posted on 16/9/08 at 03:36 PM Reply With Quote
John
I dont know whether to laugh or cry
big_wasa
posted on 16/9/08 at 04:02 PM Reply With Quote
I would try and charge the pinto. I bet you could go 4psi with out mods to the cr
mr henderson
posted on 16/9/08 at 04:04 PM Reply With Quote
John
Mave
posted on 16/9/08 at 04:08 PM Reply With Quote
As long as your not aiming for silly boost, you don't have to lower the compression ratio on the Zetec. Do a search on the westfield boardroom voor "zetec AND supercharger" and you'll find a nice example, dyno-ed at 203 bhp. The engine is stock.
alistairolsen
posted on 16/9/08 at 04:13 PM Reply With Quote
Do you really believe the power to drive a turbochager is 'free' while that to drive a supercharger is paid for in engine power?
mr henderson
posted on 16/9/08 at 04:23 PM Reply With Quote
If you use the 'quote' feature you will get a more exact statement of what I actually said,
"Turbos get most of their driving power from the heat energy in the exhaust, which otherwise would be wasted "
This is what Wikipedia says
"However, the energy to spin the supercharger is taken from the rotating output energy of the engine's crankshaft as opposed to normally exhausted gas from the engine. Superchargers use output energy from an engine to achieve a net gain, which must be provided from some of the engine's total output. Turbochargers, on the other hand, convert some of the piston engine's exhaust into useful work. This energy would otherwise be wasted out the exhaust. This means that a turbocharger is a more efficient use of the heat energy obtained from the fuel than a supercharger."
You can read all about it here
http://en.wikipedia.org/wiki/Turbocharger
Hope this helps
John
indykid
posted on 16/9/08 at 04:26 PM Reply With Quote
comparatively, yes.
tom
clairetoo
posted on 16/9/08 at 04:35 PM Reply With Quote
Top fuel cars get most of their 6000 hp from the fuel (nitro methane) , and it takes something like 1000 hp to drive the supercharger....
Pro stock cars are normally-aspirated , not supercharged
Its cuz I is blond , innit
Claire xx
Will weld for food......
<<  1    2    3  >>
