Author: Subject: What shall I do with the bump?
posted on 30/10/08 at 07:53 PM Reply With Quote
My engine used to have a down-draft Weber carb on it, so it needed a nice big air intake bump on the bonnet.
Now that I've got bike carbs this bump is totally redundant, so I'm looking for useful suggestions for how to replace it. So far I've thought of:
1. Take it off, weld in a patch. Wouldn't work due to distortion.
2. Take it off, rivet/bolt on a patch. Would look 'orrible.
3. Replace the bump with a much lower one made of aluminium... little more than a nicely-shaped bit of sheet. This is the solution favoured by Paul G (907), but he's better at ali bashing than I am!
4. Replace the bump with a much lower one made of foam covered with GRP. My favourite solution, but I'm not sure how it would look.
5. Replace the bump with some form of grille, which would be useful to let some air out after it's been through the radiator. Anyone know of a fairly large grille that may be suitable?
6. leave the bump. I hate having stuff on the car that doesn't do anything useful.
Any bright ideas?
RichardK
posted on 30/10/08 at 07:58 PM Reply With Quote
If you decide to get rid of it and flog it will you let me know please. Cheers Rich
Gallery updated 11/01/2011
New bonnet? Mines G/F so it was easy to patch and respray, so much nicer without
IDONTBELEIVEIT
re-place bonnet????
Are We There Yet, Are We There Yet!!!!
matt_claydon
posted on 30/10/08 at 08:08 PM Reply With Quote
Cut a symetrical hole opposite and cover both with mesh from behind thus providing a nice bit of extra ventilation.
philw
posted on 30/10/08 at 08:17 PM Reply With Quote
Turn it around and put an lcd screen in the hole.
Must try harder
speedyxjs
posted on 30/10/08 at 08:21 PM Reply With Quote
^^^ Like that
I would leave it. It helps cool the engine if nothing else and looks pretty cool
omega0684
posted on 30/10/08 at 09:02 PM Reply With Quote
got to agree with the above, id just leave it, looks quite nice
StevieB
posted on 30/10/08 at 09:17 PM Reply With Quote
Best left in place - it probably channels more cold air into the engine bay than it would as a plain, flat grille.
Plus, it just kind of looks right with the brooklands screens and ali body - a nice classic style
Canada EH!
posted on 30/10/08 at 09:45 PM Reply With Quote
what shall I do with the bump
Leave it there and make a plenum to direct cold air at the carbs, maybe a little forced induction at higher speeds.
posted on 30/10/08 at 10:05 PM Reply With Quote
That's a thought - wouldn't be difficult to make a duct to take air down to flow across the carbs (they're now on the driver's side of the engine)
Hmm... I see a project looming!
907
posted on 30/10/08 at 10:51 PM Reply With Quote
There are some excellent 1 day wheeling courses around....
and they aren't that expensive.
Paul G
zilspeed
posted on 30/10/08 at 11:22 PM Reply With Quote
Any bright ideas?
I would go with that one actually. If riveted and done neatly it would actually look quite nice. Not a square patch, but a curved one much along the lines of the existing bulge.
Nice and honest mod which tells the story of what happened to the car.
Triton
posted on 30/10/08 at 11:43 PM Reply With Quote
leave it on i think it looks neat and will save you work if nowt else.
Mark
www.tritonraceseats.com
www.hairyhedgehog.com
Phil.J
posted on 31/10/08 at 08:37 AM Reply With Quote
I'd just make a new engine cover. I think these cars look so much better without openings or bulges in the bonnet.
posted on 31/10/08 at 09:04 AM Reply With Quote
I'm not making another one! That was one of the hardest parts to get the way I wanted, after the rear ali panel. I even borrowed some time on a friend's huge metal folding brake to get the sides folded under neatly.
bimbleuk
posted on 31/10/08 at 09:13 AM Reply With Quote
Personally I would probably paint it black and make a guide below to feed the carbs cold air.
I think it'll be a bit plain without something IMHO. Louvres in a metal bonnet always appeal to me.
Image deleted by owner
[Edited on 31-10-08 by bimbleuk]
scutter
posted on 31/10/08 at 10:28 AM Reply With Quote
I'm a fan of the outlets idea, either one or a matching pair, remove rad heat and relieve pressure under the bonnet too.
ATB Dan.
Ninehigh
posted on 3/11/08 at 02:01 AM Reply With Quote
If you have a need for it to be useful you could always route a pipe for something, air intake, cooling, something..
