jonti
posted on 16/1/04 at 11:05 PM |
Perol Filler Cap
Any of you knowledgeable bods know the SVA reg on filler caps (really must buy a book now I'm getting close )
Anyway, do they have to be flush, or can you use one of the nice curvy old fahioned ones as used on cobras and the like ?
OFROK
zetec
| posted on 17/1/04 at 06:24 AM |
Same rules as for any other body part re radius etc, suspect you will stuggle with larger fancy job. Why not fit something basic at first and then
"modify" after the test.
Ben_Copeland
| posted on 17/1/04 at 09:45 AM |
Has to be flush fitting, old fashioned ones cant be used IIRC, or you could hide a lockable cap inside the boot.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
| posted on 17/1/04 at 01:38 PM |
i thought that the cap couldnt be in the boot, to avoid fume buildup? just a vague memory!
Put it in the boot with a lock on the lid and you don't need a locking cap. It's easier and you don't have to cut any panels. You
could try the Lumby stainless steel dogbowl recessed into the rear panel trick. It worked for him.
yours, Pete.
jonti
| posted on 17/1/04 at 04:52 PM |
Ok thanks chaps..I'll fit a flushy I think. My tank is too high to fit a cap under the rear lid...as per
OFROK
kingr
| posted on 18/1/04 at 12:38 AM |
Reading the mighty manual, it specifies that in addition to the normal radiuses and so on "...fuel tank filler caps do not project from the
external surface more that (A) 50mm where they cannot under any circumstances project beyond the extreme outer edge of the vehicle (B) 40mm in all
other cases"
Interpret that as you please. Surfice to say, I think cobra pass with aston caps without many problems. Regardless, I think a big flashy projecting
fuel cap on a 7 would look pretty daft, but that's just personal opinion.
Kingr
Ben_Copeland
| posted on 18/1/04 at 09:59 AM |
If you read RC's 2nd book, there are several pics of racers with the fuel cap hidden in the boot, reg's i think !
Ben
Roadster
| posted on 18/1/04 at 10:23 AM |
Any build up in my boot would be on the floor underneath it . Petrol fumes are heavier than air, can't see it being a problem if your boot
isn't airtight.
yours, petP
[Edited on 18/1/04 by Peteff]
jonti
| posted on 18/1/04 at 06:37 PM |
Regardless, I think a big flashy projecting fuel cap on a 7 would look pretty daft, but that's just personal opinion.
Kingr
I agree, a big flashy one would. But Mocal do a nice little 40mmD "Monza" type which I think might look quite nice. I'm gong for the
"well preserved old motor" look, not 'balls out street racer'. Thanks for the SVA info, I'll check but I susprect it
don't stick up more than about 30mm
OFROK
