Hi all, had to remove the lower steering column section that connects to the rack. The rubber joint that connects the two halves has cracked and needs
to be replaced but i can't seem to find a kit anywhere. unable to load a picture yet ( stupid iPhone!) Ive drilled out the old rivets holding it
together .
I hope my terrible description makes sense !
I doubt that you will be able to replace the rubber - best to replace the whole thing with a proper metal UJ .
Go to Dave Mac propshafts in Northey road Coventry, ask for John. He will sort it for you.
http://www.davemacprops.com/DMPHOME.html
Steve.
