hi all, anybody got a duratec to type 9 bellhousing sitting around they wish to sell?
thanks
stuart
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270465931404&ssPageName=STRK:MEWAX:IT
i saw that but did wonder if it will fit a type 9, and would i beable to use it with out a dry sump?
any one no?
if i can use a type 9 and a not a dry sump i will be bidding
stuart
Personaly cant see what diference it would make, dry sump or wet, the bell housing has nothing to do with it. I would bid on it. Cheers Ray
Only difference is the lower bolts will be positioned to suit the caterham dry sump.
Doesnt really matter, I will only be using the bolts in the block on mine and the sumps only 3" deep anyway
Are you bidding on this?
Don't want to bid over you.
cheers for the reply guys, i am bidding on it, as i will need it now, a sthe engine hopefuly should be rebuilt next weekend, and then on to accutal
progress.
cheers
stuart
