On offer from tomorrow, just £14 of your hard earned
http://www.lidl.co.uk/en/our-offers-2491.htm?action=showDetail&id=30031&ar=11
[Edited on 13/1/16 by Hodor]
I had one similar to that and it worked well for a fair few years, but then suddenly died. The ALDI replacement, that I got last year for a similar price, has an LCD display which displays mode , state of charge and voltage.
Mine never worked from the off so throw away
been using mine for about 4 years, leave it trickling out of car batteries too.
I've had a couple of the Lidl ones for years, good reliable little trickle chargers.
The only downside I've found with them is that they won't charge a totally flat battery. If the detected voltage is below around 10v on
startup it assumes a faulty or incorrect battery type and refuses to start charging.
The only downside I've found with them is that they won't charge a totally flat battery. If the detected voltage is below around 10v on startup it assumes a faulty or incorrect battery type and refuses to start charging.
Not sure where my battery charger is from - probably a panic buy from Halfords.
It works OK and doesn't complain about flat batteries either
Do you have to disconnect the baterry while charging like the video says?
I've got an optimate had it amost 10yrs it's been excellent but where i have the toycar and a bike i have to keep swapping the charger from
one to the other during winter!
so this one might be a good alternative
Thanks for the heads up Hodor, I just bought a couple, one for the car and one for the bike, got one of the £3 alternator testers too to have in the
toolbox.
3 year guarantee, and contact details included, so some backup seems available, unlike a lot of the eastern rubbish on that popular auction site.
I might be wrong, but I've seen that on many chargers, and I've never had an issue. Is it a 'just in case we fry your electrics we want our ar$e covered' kind of thing?
Plenty available in my local Lidl yesterday eve (Thurs 14th, Wokingham).
They seem to be a new design with an LCD display panel rather than the LED's of the previous offering. Also noticed something about a 'pulse
mode' to regenerate dead batteries so maybe these can charge totally flat batteries...?
Good little chargers.
I have had three fail probably a batch problem (bought at same time). The failure is a faulty push switch (could not select the mode) disassemble
quick squirt of contact cleaner and all is well, this was the old LED version.
The charger is a decent multi-stage one, you will pay three times the amount (or more ) for a branded one.
Dan
Back in the early days of car electronics alternator controls used germanium transistor which were much more sensitive to voltage spikes.
However care should still be taken with cars with smart PCM controlled alternators.
it works fine, as long as you dont have a battery which is heavily discharged.
i had it several times with my gel / race batteries that they had dischared below 6volt.
in that case those chargers will automatically change into the charging mode for 6Volt betteries and you cannot do anything against.
only solution...you bring up the batterie to more than 6v with an old-fashioned charger, than you use the modern charger.
I've bought one. I'll let you know how good it is. I have a range of batteries to try it on,...
Just picked one up so will see how it fares
Loads left at the lidl, Halton hill leeds if anyone is still wanting one
I got mine the other day in anticipation that i would drain the battery of my MK trying to start it up this weekend, but she fired up fine. Quite happy with that. Longer it stays in the box the better.
