exhaust sealing tips
jambo - 7/12/08 at 11:40 PM
any tips to get the exhaust sealed at the head.
one of my next jobs.
[Edited on 8/12/08 by jambo]
stuart_g - 8/12/08 at 09:12 AM
Use the standard gasket rings and make sure the header pipes sit square in the exhaust ports and it should seal OK. There shouldn't be a need for assembly paste at the engine end but you may need a thin smear where the collector goes on to the headers.
Peteff - 8/12/08 at 10:01 AM
Get some high temp silicone li ke this it's easier than exhaust paste.
twybrow - 8/12/08 at 11:33 AM
Surely you want to keep any silicone products away from the exhaust if you ever need to put a lambda sensor in there.... Silicone and o2 sensors do not mix (ask the 1000s of motorists last year!).
bimbleuk - 8/12/08 at 01:27 PM
Hi you can get silicone RTV liquid gasket which is compatible with sensors. I've used it fully expecting it to blow out or burn away but it lasted several weeks until I took it off again to replace the old metal gasket, I had used the RTV thinking it would be a temporary measure. Still flexible and was very easy to remove by a simple scraper or hand mostly.
amalyos - 14/12/08 at 10:33 PM
use 2 sets of exhaust gaskets, it's the only way I got a good seal.
