I am hoping to get the engine fully plumbed in this weekend, hopefully ready for firing the engine up next weekend.
But I have a few questions, I have installed an R1 5PW (2003) and plan on running my pipes as below (please tell me if I am wrong!!!!)
1 Hose from 'T' piece (front of engine) to breather tank (water pump breather hose I think)
2 Connect oil cooler to main bottom hose
3 Connect small outlet on rad to breather tank
4 Cap outlet on thermostat housing - has anyone done this or should I 'T' it into the hose from rad to breather
5 Is there anything else I should do!!!!!
Pic of outlet on thermostat that I am thinking of blocking off
fill with coolant????
Look in chris gamlins archive for r1 plumbing diagram that how i did it and its been working fine im sure he wont mind
I have a diagram of mine il try and fish it out later when im home
modified version of someone elses picture because of the mnr supplied hoses look like the bottom hose is set up for the oil cooler as ther are no t
offs in the top hose
Adam
Thanks similar to what I was going to do, but with the thermostat included. I think I will 'T' into pipe to header tank
Is your thermostat outlet pipe going to get in the way of the bonnet like mine?
i cut the little piece of pipe off drilled the rest out .tapped it and put a bolt with some sealer on it.i did this because with a pipe connected it hits the bonnet as was just said
about a year.and 2000 miles no problems
