I was just about to connect my handbrake to the cables, I have the MNR supplied cables / quadrant etc but am I missing a part of the kit or am
'I' missing something
I have the lever / switch / quadrant but can't see how they connect together, I think I am missing a connector bar but am not sure
Any ideas
Have you got the manual (we tried doing this last night but don't have the quadrant!)
It says to cut the cable, and you should have some rope clamps as well - put the cable through the quadrant, then turn it back on itself, and tighten
them together with the clamps....
HTH
Vince
It says to cut the cable, and you should have some rope clamps as well - put the cable through the quadrant, then turn it back on itself, and tighten them together with the clamps....
HTH
Vince
ahhhh, sorry, mis-read the question....
on the back of our handbrake lever, there's a joiner bar with a pivot into the lever, and another pivot onto the quadrant....
Give me 2 minutes and I'll upload some photos
HTH
Vince
[Edited on 21/2/09 by vinny1275]
There should be a connecting bar between the handbrake lever and the quadrant.
Too slow
Oh no something else missing from my kit, I will have to get onto MNR on Monday
I havent got a sping
what does it do?
I havent worried about the connector you dont need a handbrake light for sva just low fluid light. I ended up using two sierra cables and using the
sides with adjusters - lots of faffing about not a great design as i couldnt see how its all held in place through those holes in the chassis so im
using the adjusters on the cable.
[Edited on 21/2/09 by bassett]
Originally posted by bassett
I havent got a spingwhat does it do?
