ZX14 MNR gearbox issues - also spotted Bright orange MNR jct 24 M1
GBaggott - 2/5/09 at 07:10 PM
Hi all,
At the start of today i was well chuffed, finally got the zx14 engine swap complete and ready for the first road test.
The engine is so powerful and just spinning the wheels and going sideways
On my third test run i down changed and a mechanical crunch type noise came from the engine. An F1 alarm came up on the zx14 dash?
Now i cannot change gear? I assume something in the gear selector mechanism has gone wrong? Anybody had similar problems or got any ideas?
Thanks Gareth
Oh i seen a bright orange MNR at around jct 24 on the M1, If you were coming back from the sva station at 26 i hope you passed.
blakep82 - 2/5/09 at 07:25 PM
best fond out what this F1 warning is. i'd doubt the actual linkage has gone wrong, i think its refusing to change gear because of the warning. if you can find out whats giving the warning and get it reset
Omni - 2/5/09 at 07:37 PM
You need to find out the error/service code. Once you know that you will know the issue.
To get the service code for the FI error
1) Turn the Ignition Switch ON
2) Push the Mode and Reset Buttons for more than 2 seconds
The 2 digit service code should then be displayed:
I am looking up the service codes now
O
Omni - 2/5/09 at 07:47 PM
You will find the manual with ALL the service codes (and how to fix them) HERE
Hope this helps.
O
GBaggott - 2/5/09 at 07:59 PM
Thanks very much Omni,
Hopefully i can get it sorted for my trackday next weekend,
