VortX Fuelpump placement?
Triggerhappy - 18/5/09 at 04:16 PM
Hi,
Where did you put your filters and pump?
Pics, preferably BEC installations.
Michael
Pdlewis - 18/5/09 at 04:58 PM
Not the best picture but i have my pump fitted behind the diff
richardh - 18/5/09 at 05:08 PM
pump is near diff under the tank - ish
filter is in engine bay
now if i did it again then i'd filter it before the pump and then a 1 way filter valve in the engine bay
stops that annoying pump going to fill the pipe and then the filter before i can think of starting it
blakep82 - 18/5/09 at 05:29 PM
and stops crap getting in the pump too
cosmick - 18/5/09 at 06:31 PM
If you are building your car now, why don't you put a standard Suzuki fuel pump in the bottom of your tank. this will be a very good position and will allow you to use only one fuel line to the engine.
i modified mine over this winter and the result is that i now have a much neater supply and i have an accurate fuel gauge because the Suzuki pump also has a sender.
You can fit a high pressure fuel filter outside the tank immediately as the pipe comes out of the pump.
You will not need to use a pressure regulator as the pump regulates in the tank.
bassett - 18/5/09 at 06:38 PM
Pics in my blog below if interested. Best place i thought it would go is below the left driveshaft on the chassis rail, I made two pump sized brackets in ally strip and bolted it to the chassis. Also used chassis foam for a tighter grippy fit.
Adam
Wheels244 - 18/5/09 at 07:21 PM
I did the same as Adam, but used rubber lined P clips
coozer - 19/5/09 at 07:22 AM
Mines about the same place as the one above with a filter before and another up in the engine bay.
Mine being carbs, gravity fills the pump to give it an easier time.
