MNR Vortx Ride Height (Front/Rear)
spdpug98 - 31/1/10 at 12:44 PM
Just a quick question as I can't remember the passwords for the build manuals
I am just about to go into the garage and change the setup on the front of the car, I know that the front arms should be level with the floor and then the rear should be 'x' mm higher (measured from font of wheel arch/chassis rail)
Can anyone confirm what 'x' is, I think it is 25mm but am not sure
Steve Hignett - 31/1/10 at 12:49 PM
It's open to choice, but between 15-25mm sould be fine...
spdpug98 - 31/1/10 at 01:28 PM
Cheers, I will work on 25mm then
GeorgeM - 31/1/10 at 01:30 PM
25mm is where mine is too
GeorgeM
richardh - 31/1/10 at 02:17 PM
mine were 25mm too.
