4 point / 6 point seat belts arghhhh
The Venom Project - 31/1/10 at 11:57 PM
I just found out today that one set of my 4 point belts are bloody 6 point belts. If I send my car for the IVA without the passenger seat belts I assume it will fail wont it? However if I take the seat out and send it as a car with the race re-enforce bar fitted from the crossbar to the floor, would it pass? I have a 4 point Willans harness but it will have expired on the FIA dating.
Any ideas?
or is anyone selling 1 or a pair of 4 points within date?
blakep82 - 1/2/10 at 12:02 AM
i thought a lot of 4 points are just the same as 6 point but without the bottom straps?
IVA won't worry about FIA dates either.
Steve Hignett - 1/2/10 at 12:09 AM
My harness wasn't checked for being in date. Is that part of the S/IVA?
If so, surely someone near to you could lend you one for the day?
The Venom Project - 1/2/10 at 12:18 AM
The problem with my 6 point belt is that the quick release unit is part of the lower belt system,
I will see if MNR can lend me one if its needed, otherwise I will fit my spare Willans.
jeffw - 1/2/10 at 06:07 AM
Fit the Willans, they don't check the date on the belts.
TimC - 1/2/10 at 09:18 AM
Depending om the belts, some can be unbolted and moved - watch out for springs shooting off when you take it apart though.
The Venom Project - 1/2/10 at 10:31 AM
Cheers fella, I have nothing to lose really so I will have a look into that as this is a much nicer proposition. Failing that I will fit my spare Willans for the time being.
Cheers guys
The Venom Project - 2/2/10 at 01:28 PM
I took the advice and took them apart and rectified the 6 point belt right out of the equation. Will try it tonight, but I think its acceptable.
