is there anything specific i need to know when purchasing a header tank. my rad has no cap and my engine is f20c honda lump. diamiter and no of
in/outlets? pressure rating of cap? size ( in litres)?
have seen a nice ally one from demon motorsport on ebay at £49 posted with 0.5 litre capacity!
£ 50? a tenner for OEM car one off ebay, that will be transparent, something aluminium is not, hence will allow you to spot any water loss or other
coolant troubles quite quickly.
... but as you say, the diameter of the outlets should match the radiator/water pup but you can buy hose reducers if needed.
Probably at least as important as capacity is how big it is, to make sure you can fit it to be the highest point in the system....
you can get ali ones with level switches....
Daniel look at the header tanks that are fitted to citreon berlingo's they are perfect shape have suitable outlets and come with a level sensor
attached so can be wire to a dash light and as there are loads of berlingo's on the road it'll be cheap as chips
http://cgi.ebay.co.uk/1998-CITROEN-BERLINGO-MK1-1-9D-RADIATOR-EXP-BOTTLE-/390181194195?cmd=ViewItem&pt=UK_CarsParts_Vehicles_C
arParts_SM&hash=item5ad89c89d3
P.S. loving the new Kit Car, you should get yourself upto our 1/4 mile drag days on the 17th & 18th of July@ Kirkbride
[Edited on 15/6/10 by silky16v]
might do matt. cheers
