Evening all,
Ive had a quick leaf through the manual, but to no good. I have an idea but where this goes but does anyone know for sure?
Measurments are give or take a little bit as they were done with a flexi measuring thingy. The 2 measurments you might not be able to see are 200mm
and 80 mm.
Rgds
John
Does it belong above the passenger (or maybe driver) footwell as a cover?
A guess on a MNR under the scuttle next to your knees it makes a shelf to put junk on
Jacko
[Edited on 5/3/11 by jacko]
John,
some scuttle pannels had a cut out for getting down to the pedal area from above ( from the engine bay ) if the pannel above your toes does no have a
coresponding hole leave it in the spares box just in case.
REgards
Agriv8
Im guessing it goes where ever you havent covered with other panels.
Pointless asking anyone like me with a older car, as the MNRs are changing so much the panels are differant every time i see one.
Originally posted by Agriv8
John,
some scuttle pannels had a cut out for getting down to the pedal area from above ( from the engine bay ) if the pannel above your toes does no have a coresponding hole leave it in the spares box just in case.
REgards
Agriv8
Spot on.
Thanks all
Ah, i was just thinking the other day i could do with a hole in that panel so i could adjust my clutch pedal, obviously marc thought of this and now makes them, thats another job for my list, just need a sheet of ally now
