Chassis number & chassis plate
mark w - 24/6/12 at 03:30 PM
Hi guys, I know that the chassis number has to be located on the offside of the vehicle but I'm just wondering where everyone has put there's & also any tips on how not to chip the powder coating off or damaging the chassis rail? My chassis plate has manufacturers name at the top & then has MNRVORTXRT printed on it, has everyone else stamped the remaining digits or have them engraved? Cheers mark
daniel mason - 24/6/12 at 04:29 PM
be careful when doing the chassis number and speak to both mnr and iva first. i put mnrs number on mine and it failed for having the letter I in it. cant remember exactly but something like MNRVORTXRTIB for in board. iva tester said it should be the number1 as letter I is not allowed.
mark w - 24/6/12 at 06:12 PM
Thanks for the heads up on that as I'm sure I would have made that mistake as well, I best alter my IVA1 form as I'm sure I've put IB on that for Inboard
BigLee - 24/6/12 at 07:50 PM
I stamped mine on a scrap of metal 4 inches long, then welded that to the diagonal rail just above and infront of the pedal box. Good job I didn't do it direct to chassis as I messed the first one up. The number was exactly as MNR gave me, but without the IB. Basically as Dan typed but with chassis 138. Out of interest, what's yours Dan?
stevegough - 24/6/12 at 07:51 PM
Be careful if you are stamping the chassis tubes. It can and will dent it. Certain letters stamp easier than others. Start in the middle and work outwards. I've heard it said its better to stamp a separate plate then weld it on.
Also - I failed my test by putting it under the nosecone - had to resite it. see photo.
[Edited on 24/6/12 by stevegough]
daniel mason - 25/6/12 at 06:31 PM
my tester failed me for making my own plate. i riveted an engraved plate to a chassis rail but he said it needed to be a manufacturers plate. mine is 136
mark w - 27/6/12 at 07:24 AM
Thanks guys, can anyone else shed any light on this?
big_l - 6/7/12 at 07:29 AM
Usual iva inconsistency I engraved mine on the underneath of the front chassis rail
He made me make a ali plate with it on and double sided it to the bulkhead ..
loggyboy - 6/7/12 at 08:24 AM
Unless Raw advise me other wise (ie they have their own) I will be buying ones of these.
I already have an engraved chassis number from that Raw put on, however as metioned above, they also foolishly put a I in it, which have since changed to a 1!
http://www.vin-plate.co.uk/iva_kit_car_plates.html
Steve, when you were failed for having it under the nose cone, was the the VIN number, or the VIN plate?
[Edited on 6/7/12 by loggyboy]
stevegough - 6/7/12 at 08:23 PM
It was the VIN number - I'd stamped it into the only available bit of chassis tube available on the RHS. He didn't like it there as it wasn't readily visible with the bonnet off. He suggested I made the hole in the ally footwell cover to access the rail underneath. This is what I ended up doing.
mark w - 2/2/13 at 06:16 PM
Been putting this job off for quite a while now, It's about time I made a decision & did something, think I'm swaying towards engraving the chassis rail unless anybody else has got any info on this?
loggyboy - 2/2/13 at 10:51 PM
Definitely the sensible route IMO as I read a thread here recently where someone failed on a stamped plate welded to the chassis as the (stupid) tester deemed it could be replaced!?
