Hi
I have decided I want to build a Vortx using the mx5 donor just got a quick question about which mx5 I can use I was sure I read per 95 only but have
since read differently can someone please clear this up for me I know either 1.6 or 1.8 will work just the age range I'm confused with
Tri
Apparently, there is one with a particular crank issue, but I forget which is which. There was a CKC article a couple of months ago on this, by John Dickens.
it,s the really early ones that are affected,if the fan belt pulley has 4 slots it,s a short nose and need looking at,if it has 6 slots it,s ok
[Edited on 26/8/12 by theconrodkid]
Thanks for replies did not know about the engine problems does it matter the year for the kit or will most be able to be fitted
Tri
I'm running a Miata Vortx, from a '99 miata.
IMO go with the 1.8 ('94 and later)
-more power
-Better diff (Torsen, rather than the VLSD in the 1.6L), also stronger
-Stronger Transmission
-bigger brakes (not really needed for a locost)
the early 1.8L's ('94-'95) were OBDI (simplier emissions), compared to the '95+ which are OBDII.
check out the below link, it lists all the miata from '90-'97, it's helpful in figuring out which ones came with a LSD; I've
found it's a good gauge, but I always call Mazda anyways to run the VIN and double check what options it came with...so many people mod them.
http://www.miata.net/faq/Miata90-97A3.pdf
hope that helps!
