Is it possible to retrofit a full cage to a vortx easily or is it a back to factory for bits to welded on?
Yep, I fitted a front loop and bars to the room bar on my MNR.
The roll hoop was welded in and I made the front bit bolted in. It was a front loop with two bars back the original bar with a diagonal across the
top bars.
here it is...
Same as I did with my Striker then. Just looking for a suitable MNR then now.......
