new range of silcone hoses coming soon, in yellow, purple, green, red, blue, orange, black
from 9mm id to 127mm id
90
45
135
t peices
reducer hoses
reducer elbows
hose joiners
details will be on our website middle of next week under cooling
10 % disconut on all oredrs to locost builders
dont forget we can also provide steel cooling pipes bent to your spec powder coated
best regards
marc
[Edited on 25/8/05 by marc n]
ooh, never heard of you guys. ive been looking for someone to buy me polybushes from instead of gts! bit in the dark ages yer site though, no online
ordering!
bloody cheap though! i have a quiestion- do you know the weight per meter of the 35mm cds you use for roll cages, mild steel and the t45. also- what
is t45? can i weld it normally to steel?
Russ.
You really are going all out aren't you Marc!
Are these made by Samco or by a local supplier? More cost effective (the girlfriend likes me to use that phrase...) than the Samcos?
Chris.
[Edited on 25-8-05 by Winston Todge]
Originally posted by suparuss
bloody cheap though! i have a quiestion- do you know the weight per meter of the 35mm cds you use for roll cages, mild steel and the t45. also- what is t45? can i weld it normally to steel?
Russ.
it doesnt say on the site what wall thickness is. i couldnt see it anyway.
