I have a feeling that my front ride height is too low.
The lower 'bones are parallel with the floor but the lower edge of the nose is really low.
What sort of clearance should I have?
Hi paul
Mines only rt but i have about 105mm from lower edge of nose to floor if thats any help to you
Looks about right, I haven't measured mine, but here's a picture. It looks about the same.
I have caught the bottom of mine a few times but not too many problems.
What size boots do you have?!
185/60/13's at the front.
as you say a guide
( and I thin i am right - even after the sunday trip to the pub ) as a rule of thumb your front lower wisbones need to be parrelel to the floor so yup
chocket jack her up and a few turns on the shocker platforms.
im sure Marc will correct me if i am wrong
from the photo looks like they are still need a little more.
to get it spot on will need a visit to some flat patches and corner weights.'
regards
agriv8
[Edited on 26/11/06 by Agriv8]
I'll have a measure with the car on flat ground, the area outside the garage slopes towards the door, so the rear of the car was higher than usual.
