I got a wire list with my wiring harness but i never recieved the diagram, its just i keep losing my ECU feed and would like to trace wire back to the
supspected faulty relay.
any help is appriciated!
Diagram?
There was a diagram?
Yeh, same here. Ive not heard of anyone having a diagram.
I assume youre talking about a perm +ve to your ECU?
Have you confirmed there is definately not perm 12v on the Green from the fuse box?
The relays are identical so to confirm a suspect one is easy enough.
Never got a diagram with mine either, just the booklet which identifies all the wiring
[Edited on 5/6/07 by neilj37]
well sometimes when cranking i loose my ECu feed, and therefore cant start the car, never had much time to look into it yet, but im sure there is a wiring diagram out there!
