Went for quick blat today
Getting used to it now and giving it a bit more right foot decided to try a rolling start so got moving give it some beanz and bang! (what the
smuck?)checked under rear and mounting point for diff had snapped and mounting point from chassis all bent not sure what to do ?
Is it possible to remove 3.38 internals and place in another 7"sierra diff ?
And what would be plan of attack for chassis any ideas
Absoulutley gutted
many thanks
Martin
got any pics ?
Will post some tommorrow all been well just fancy looking at again today! beers are out and the kleenex
They are swappable into other diff bodies, even into LSD 7" diffs. I have spent an absolute age researching this very topic after my diff went a
knacker.
You just need to salvage the CW&P, assuming no other damage has been done
My first port of call would be MNR!
Simon
Martin.
Email Marc and Chris. Should be easilly sortable.
regards
Agriv8
I'm not saying it can't be sorted, but easily sorted could be a slight exageration surely, for a newly built car that is fully
finished, thats just lunched it's diff and ripped heavy duty mounts off a fully welded and powdercoated chassis???
M
Originally posted by Agriv8
Martin.
regards
Agriv8
hi martin
best send me some pics, to do that sort of damage somthing isnt right somewhere in the drivetrain i would think at first guess, shouldnt be to bad to
rectify inc locolasied powder coating
cheers
marc
Originally posted by A Nonny Mouse
I'm not saying it can't be sorted, but easily sorted could be a slight exageration surely, for a newly built car that is fully finished, thats just lunched it's diff and ripped heavy duty mounts off a fully welded and powdercoated chassis???
M
Martin.
regards
Agriv8
[Edited on 14/10/07 by A Nonny Mouse]
. quote:
Originally posted by marc n
shouldnt be to bad to rectify inc locolasied powder coating
cheers
marc
That sounds quite bad actually - as Marc has said send him some pictures. Not on here though eh (you know what I mean)...
MNR - Churning the money into the business by buying a localised powder coater - mmmm VERY pro-active!!! You go from strength to strength!
I would say loose bolts of diff input flange bolts, allowing prop to come loose.
) and all it did has elongated the
mounting holes ( and that's with a Sierra LSD and V8 tourque - though suspect it also depends on how Sticky the rubber is ?? squeel vs grip as it
were - I am not running Sticky rubber BTW ). we only have the powdercoating system to do small rush parts typically, as it is a smelly messy job
all chassis and bones are done by a local company
we have just invested in a cnc bar feed lathe also to enable us to be more self sufficient
we get let down by suppliers all the time so we are gradually trying to eradicate the need to deal with unreliable companies by making 99 % of parts
inhouse also helps on the development side too
cheers
marc
Ive just been looking at my car and the welds that are nearby the diff look well beefed up and Im sure the diff brackets are sufficent for the
job(well i hope they are) if they can handle the V8 torque, im sure they can handle my 4 -pot!!
So what on you car have you found that may be the cause?? the diff locked up??
Spoke to chris n marc sent the pics over and their commitment to customer service is absolutley fault less 120% dedicated.
They make it sound so easy and even though there snowed under with work want to collect car and inspect all possible causes but looks like diff
giveway first causing rest to twist under the load
Martin
i was thinking that if the diff mounts cracked off the diff, or a few bolts came out, the reactive torque from driving would have more effective leverage over the remaining bolts.
i think that one side of the diff came loose,
then automaticly if you aplly power it will twist one way or another and take (practicly any type of mount with it)
Tks
