hi all just been off the phone to Chris and the kit, RTIB, will be ready to pick up on the 25/1/08, cant wait to get fired into it !!!!
just got a couple of questions regarding parts, i m sure i have everything else covered (i hope)
1. does the ignition barrel and keys come with the loom ?
2. does the indicator fittings/lever come with the steering coloum ?
i think thats all thats come to mind recently but i m sure there will be many more questions lol
cheers
Finlay
NOPE and depend who you get it from for second question!
Are you buying everything from MNR? If you are then you'll have to ask them.
If you are just sourcing your own Sierra column, you'll find that the barrel and indicators are integral to that.
You have a couple of options:
1. Use the column as is.
2. Remove the switchgear and gubbins from the column and use other switches, ignition switch in or under the dash.
Its down to personal preference really.
TC
Just got my kit and MNR supplied a donor column which came with everything inc ignition barrel and switch gear.
i m getting everything from mnr, but from the last post by gr8ging it looks like everything is supplied
thanks for the info folks
cheers
