Hows the bottom of the dash for SVA? Does it pass as is or does it need some 'modification'
I can smell the finishing line now...
yeah looks great with my special x-ray specs!
I can't see anything wrong.
Well since you are posting clearly in the MNR section I'll assume you are referring to the MNR Dashboard? Then Yes they pass OK - the only thing
you may have to do (for a fussy examiner?) is to put U Trim on the underside edge, but just take some spare and do it while your there...
Sorry chaps, I was indeed on about the MNR dash!
Thanks,
Getting close now Steve!!!
How close are you Tim? Considering your cheating now!
I'd be right up with you if my uprights hadn't gone missing in the post for 50-odd days.
The bodywork is on. The back-end is almost there. Front is awaiting machined uprights and pins, need to finish the plumbing and then set the whole
thing up.
Close!
[Edited on 15/1/08 by TimC]
