hi all
quick question
before i fit my front indicators, i happened to see this pic on a different post
would these front indicators pass SVA ?
if not, why ?
cheers
Finlay
probably not, i don't think they would meet the Dimensiona requirements of teh SVA manual.
But post SVA is a different story....
Nope they are too far inboard to meet the requirements.
you need a pair of extended ones to fit for SVA then fall off afterwards.
MNR loan you the correct indicators for the SVA test, along with mirrors and a cat.
I think you will find that car is going through SVA right NOW.
What you need is something horrible like this...
I think it's 400mm in from the widest 'rear' point.
It's the widest point of the vehicle, not necessarily the rear
Front Indicators , Max in from edge of vehicle 400mm , Min seperation 500mm ,Max hight 1500mm , Min height 350mm .
Mike
I think what he was trying to say is that it's the widest point, and that is often the rear...
cheers for that, is MNR putting your car through its SVA ?
will the nose cone fit round those indicators at the bottom ?
[Edited on 23/5/08 by finlay]
That diagram is not in the current manual, there is a table which clearly states 400mm maximum from the edge of the vehicle.
This pic should help
that is the best drawing ive seen
cheers
