where do i start,
should i have received a build manual or is it guess work?
pic 2
the build manuals are online - go to the MNR website and click on the links option - you will find the manuals there.
You will need the passwords for the 2 build manuals - drop Chris an email and he will sort you out with the passwords
Paint the floor. Your garage is hardly up to Mclarens levels of cleanliness.
Hi
welcome to MNR land
build manuals are off line at the moment
for update,- marc keeps improving the car
so they were a bit out of date!!
as said email chris - i'm sure they will
get one to you somehow
good luck with the build
Engine fitted already so you are halfway there
I have a set of 3 VHS build videos for a Robin Hood Series 3 circa 1997, absolutely no use whatsoever for building a car but will guarantee the lounge
TV.
In all seriousness that is one comprehensive kit, don't put any bodywork on until the last possible moment and when you do bubble wrap it to stop
annoying marks. Try not to use the scuttle as a work surface.
Wow - that looks like a seriously comprehensive kit!
Enjoy (orange cradle looks ace by the way!)
Looks like you've done what I did - a one stop shop with MNR.
Your kit spec looks almost identical to mine, with the exception of I went for the full cage.
If I can be of any assistance drop me a line.
Best of luck with the build.
Job number 1
Make a cup of tea and look at all your stuff..... very exciting moment that!
Seriously i found the 1st job on a MK was to put the rubber bushes in the wishbones (with rubber grease) and bolt them on the car.
[Edited on 8/6/08 by donut]
you seat in the car and pretend to drive it with sound effects.
with a short video on yutube to show you have done it,
Originally posted by donut
Job number 1
How much did that lot cost you!
With all the bits there, then it shouldn't take you any more than 2 months to build so make that coffee and crack on!!
That's a hell of an impressive kit - quite fancying an MNR as my next build.
Which model is it?
I know you said you were getting a comprehensive kit, but I didn't think it would be that comprehensive. Did they give you a jerry can with the fuel for it as well. Good luck with your build.
Great shot with the parts spread out on the floor...
We don't dare to do that, fearing we will never ever remember again what needs to go where...
Great kit, good choice of colour!
Ours is very similar, again, with full cage.
Let the build begin!
Although, if you are asking questions about the reverse, you must already be building... not fair!
First jobs according to the manual:
1. Alloy footwell bulkhead panels
2. Brake pipe / fuel line fitting
3. Wiring loom fitting
That should take you a couple of hours...
Gergely
