MS 2 fan control
t11 - 30/5/14 at 07:05 PM
Hello all......how can I alter the temp at which the fan cuts in and can I also set to when the fan cuts out, using tunerstudio.....thanks
coyoteboy - 30/5/14 at 10:00 PM
Depends which output it's programmed to use for the fan. IF it's set up as fan control you just find the fan control option in tuner studio?!
dave_424 - 31/5/14 at 12:31 AM
Extended, output port settings.
Then find what output you have your fan relay wired to, threshold is a set temperature and hysteresis is the temp either side of the threshold that it will come on and turn off
shaunod - 13/6/14 at 06:35 PM
Look in output port settings. May well be FIDLE unless you are using a two wire idle valve. Just change the temps to suit.
