Halfrauds - What's a cotter pin?
Xtreme Kermit - 19/11/12 at 08:56 PM
I must be getting old...
Thinking that you get spare bit for bikes in Halfrauds, I went in to get a set of cotter pins for an old bicycle my daughter uses.
Me: Hi, do you have any cotter pins?
Spotty pre-pubescent assistant: What are those then?
Me: They used to hold the pedals on in the seventies...
Spotty pre-pubescent assistant: Oh. We don't keep part for old bikes.
Whats a cotter pin??? . Arse!
bi22le - 19/11/12 at 09:02 PM
Sorry, I dont know what a cotter pin is either. . . .
AdrianH - 19/11/12 at 09:04 PM
Spilt pin!
Adrian
big_wasa - 19/11/12 at 09:07 PM
horrid things, I never could get them out.
[Edited on 19/11/12 by big_wasa]
coyoteboy - 19/11/12 at 09:10 PM
That's not a cotter pin wasa? That's a tapered axle (still exist, though usually square taper).
This is a cotter pin:
mark chandler - 19/11/12 at 09:11 PM
I would call a split pin a split pin, a cotter pin is the thing with an angled shaved edge that pins the pedal arms to the crank.
But then I am old, how do they secure pedal arms to cranks these days?
Big_wasa' pic
[Edited on 19/11/12 by mark chandler]
ReMan - 19/11/12 at 09:16 PM
Yep and I used to wear them out being erm "heavy' on my bikes before BMX's were even thought of!
hillbillyracer - 19/11/12 at 09:18 PM
Cotter pins are the tapered pins that hold cranks to old bikes & kingpins into axle ends on old vehicles, if they dont go in the first couple of sharp knocks with a hammer they'll be a right cnut!
A split pin is a split pin.
coyoteboy - 19/11/12 at 09:18 PM
Current method:
Cotter pin:
http://en.wikipedia.org/wiki/Cotter_pin
I've apparently always known the US version
[Edited on 19/11/12 by coyoteboy]
mookaloid - 19/11/12 at 09:21 PM
British Cotter Pin
American Cotter Pin - split pin in English
big_wasa - 19/11/12 at 09:22 PM
Taken from wikipedia, so it must be true !
Cotter pin may refer to:
In U.S. usage:
Split pin, a metal fastener with two tines that are bent during installation used to fasten metal together, like with a staple or rivet
Hairpin cotter pin, more commonly known as an "R-clip"
Bowtie cotter pin, a vibration-proof type of R-clip that is shaped like a bowtie
Circle cotter, a ring-shaped cotter pin
In British usage:
Cotter (pin), in mechanical engineering a pin or wedge passing through a hole to fix parts tightly together
This usage difference is often a cause of confusion when companies of both countries work together.
beaten to it by mook
adithorp - 19/11/12 at 09:24 PM
Wasa's picture IS a cotter pin.
A "split pin"as in the other picture, is actually really called a "split cotter pin" and something entirely different thing.
stevegough - 19/11/12 at 09:28 PM
Big Wasa (and Mark Chandler) are right, Coyoteboy obviously works at Halfrauds
They are now secured by having a square, tapered bottom bracket shaft, with a matching square tapered hole in the pedal crank, the ends of the shaft have a fine-pitch thread into which a bolt is screwed to retain the crank, this is recessed into the body of the pedal, then finished off with a plastic cap.
See pic on the link ---> linky
The exception to this is BMXs which have a one-piece crank.
Ninehigh - 19/11/12 at 09:31 PM
I was thinking a cotter pin was the one in the back wheel that allowed you to freewheel
Xtreme Kermit - 19/11/12 at 09:34 PM
Yep, I'm with wasa on this. Its the taper jobby
Leave this nut on loosely and whack it with a club hammer. If yer lucky it'll come loose.
Looks like I'll have to try a proper bike shop, as I'm guessing the eBay ones will be made of chocolate...
Interesting about the American connection. Never expected that.
adithorp - 19/11/12 at 10:08 PM
The trick to removing is to hit the other end first. Counter-intuitive but it works.
Canada EH! - 19/11/12 at 10:12 PM
From the Colonies, a split pin in North America is called a cotter pin. The metal retainer which holds the axle nut from unwinding and falling off the spindle closely fallowed by the front wheel.
ChrisL - 19/11/12 at 10:14 PM
I was in there out of desperation on sunday after brake bleed nipples for an MX5, 'huh' was my response
austin man - 19/11/12 at 11:07 PM
definitely the tapered one a split pin is as it says a pin that splits usaully used through a castleated nut fitted many of these on Raleigh choppers oh and on the bottom of the Austin a35 Kingpins
Andi - 19/11/12 at 11:15 PM
I was asked what a Sierra was last year at my local Halfords.
Peteff - 19/11/12 at 11:23 PM
A different type of cotter pin used to hold the handbrake cable into the lever on back axles. It was like a nail with a hole drilled in for a split pin to go through.
Westy1994 - 19/11/12 at 11:27 PM
Yes I remember Cotter Pins, I used to stock up on them back in my cycling years, but your story reminded me of another example of stupidity with todays shop staff. About 15 years ago, when I was Hillclimbing, I took a brand new set of Yoko slicks and some wheels to Kwickfit, I was stood there a good 20 mins before getting the attention of someone, despite them knowing I was there. After a while I had to go over to a guy after someone wwho had just walked in got their problem sorted out in seconds, the guy said " I am not putting those tyres on those wheels because they are totally bald"....... I kid you not they were the words he used.... I said I know they are bald, I paid dam good money for them to be such.... This confused him somewhat, and went to fetch his boss..... Who apologised and gave me a discount for the wasted time and ignorant staff...
The lad wasn't there a week after that.....
indykid - 20/11/12 at 12:10 AM
You'll be lucky to find m8x1 bleed nipples even in a good motor factor's. I had to get mine from brakes international.
Ninehigh - 20/11/12 at 07:19 AM
Probably thought you were some sort of pervert after hearing "break bleed nipple"
liam.mccaffrey - 20/11/12 at 07:36 AM
I've had real trouble finding bleed nipples locally. I did manage to find a lorry mechanic who had a big stash though.
MikeRJ - 20/11/12 at 08:15 AM
That sounds like a Clevis pin to me Pete!
britishtrident - 20/11/12 at 08:47 AM
That's a Clevis Pin because it fits into a Cleviis
flibble - 20/11/12 at 08:59 AM
So what are the little doodaads called that resemble a very small tube with a slit down one side (from end to end)?. Needed one a few weeks ago and no idea what they're called!
Macbeast - 20/11/12 at 09:37 AM
A Roll pin ?
coyoteboy - 20/11/12 at 09:40 AM
Big Wasa (and Mark Chandler) are right, Coyoteboy obviously works at Halfrauds They are now secured by having a square, tapered bottom bracket shaft, with a matching square tapered hole in the pedal crank, the ends of the shaft have a fine-pitch thread into which a bolt is screwed to retain the crank, this is recessed into the body of the pedal, then finished off with a plastic cap. See pic on the link ---> linky The exception to this is BMXs which have a one-piece crank.
No, I just have picked up americanisms it seems Plus in many years of engineering have never had to resort to a cotter pin
Oh, and now who works in halfords - square taper is old hat
coyoteboy - 20/11/12 at 09:45 AM
FWIW I have just found this etymology online:
"The terms cotter and "cotter pin" are sometimes used interchangeably, although they have different functions. Basically a cotter holds parts together and a "cotter pin" holds the cotter in its place."
Which is the way I'd always assumed it to be, but who knows
ChrisL - 20/11/12 at 09:50 AM
ebay for fronts and mx-5 parts for rears, re cotter pins, I'm in the wedge bolt thing camp
