honda 918 engine not running right
brookie - 20/8/10 at 05:12 PM
as above my engine not running right it runs fine up to 5000revs and then from 6000revs but in between them it runs poo it cought and pharts any idea
Gav - 20/8/10 at 06:06 PM
I take it your carbs have been jetted?
I got my jet kit from Andy Bates and used his settings, he told me that it makes it run too rich in the midrange but spot on for the top end.
Mine doesnt cough but does feel like its struggling to get over that part of the rev range when its not quite up to temp.
I would perhaps check that the air holes are still blocked off properly?
bob tatt - 20/8/10 at 06:15 PM
the engine has been jetted, cause it used to be mine. cant help on the poor running though never had any bother with it so never needed to investigate.
brookie - 20/8/10 at 07:37 PM
what jets did u use m8
MK9R - 20/8/10 at 08:23 PM
Have you done a plug change? checked and cleaned float bowls? Checked jets for crap? Is fuel pump running ok? Checked for air leaking into carbs?
rgrs - 20/8/10 at 09:37 PM
Try removing the air filter and see if the problem still exists.
Althought i used Andy's jet kit and instructions i had the same issues using the airbox and panel filter.
After fitting a saussage filter it is now perfect.
Or else phone Andy.
Roger
brookie - 21/8/10 at 10:45 AM
iv run it with out the air filter(sassage filter)and still the same
any body got andy number if so can u u2u me it please
brookie - 22/8/10 at 12:16 PM
any body go tandy number or what is name is on here so i cam pm him
