ZETEC COOLING SYSTEM DIAGRAM
Dooey99 - 27/12/12 at 06:41 PM
After Searching high and low for a decent Zetec cooling diagram, i gave up. i ended up making it up and using trial and error trying to find the best way to arrange the hoses and so on. this is what i finally came up with, my engine is a 1.8 zetec black top but this should work for any zetec engine, there is no need to change the water pump so it pumps the other way leave it with a standard pump.
AndyW - 27/12/12 at 08:16 PM
Save yourself some hose and just blank the top rad small outlet that's what I did and works fine.
gavin174 - 27/12/12 at 08:45 PM
what rad are you using..
obviously not polo as the outlets are on different sides..
Dooey99 - 27/12/12 at 08:48 PM
I'm using an escort mk2 rad and just leaving the radiator cap on and sealing it properly.
whitestu - 27/12/12 at 09:35 PM
+1.
alladdin - 27/12/12 at 10:03 PM
any reason you didnt or could,nt T the two red hoses at the expansion tank ?
paulf - 27/12/12 at 11:09 PM
My car has been plumbed like that for a few years with no problem, but people seem to think that you need 2 separate hoses for some unknown reason.
Paul
Paul Turner - 28/12/12 at 10:05 AM
My diagram is about 1/2 way down this tread and was kindly posted for me by Lewis.
http://www.locostbuilders.co.uk/forum/9/viewthread.php?tid=161780
Has worked perfectly since 2001.
