Author: Subject: Calipers fouling !
Wells
posted on 22/12/08 at 12:46 AM Reply With Quote
Calipers fouling !
Just replaced my 2 sierra rear calipers with 2 reconditioned ones. They are identical but now the hand brake springs are touching the rear wheels. Have any one else come across this? Compomotive 13" CXR wheels fitted if that helps.
A1
posted on 22/12/08 at 01:37 AM Reply With Quote
are they any different from the old ones? i thought you needed 15" wheels for them?
PAUL FISHER
posted on 22/12/08 at 01:47 AM Reply With Quote
The standard sierra rear calipers do fit inside the 13" cxr's but you just need to bend the hand brake lever arm for them to clear,it may be that the calipers you are replacing have already had this done to them.
mcerd1
posted on 22/12/08 at 08:26 AM Reply With Quote
Originally posted by A1
....i thought you needed 15" wheels for them?
the sierra's use 14" and up
but some 13" one fit (as above)
bigrich
posted on 22/12/08 at 08:54 AM Reply With Quote
+1
or remove the coiled spring and fit a spring over the HB cable between the arm and cable stop
Gergely
posted on 22/12/08 at 10:53 AM Reply With Quote
Hi, we have the same setup, had the same problem. We filed the spring retainer bolt so it could get screwed in further, bent the handbrake cable arm and also had new springs made with one less coil on them. This way it JUST fits...
Picture here:
Left - original spring, right - new spring
And the final setup:
caliper setup
Gergely
Our build pictures
marc n
posted on 22/12/08 at 11:09 AM Reply With Quote
it seems to depend on where they have been reconditioned it would appear, i would swap your original springs onto the calipers
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
britishtrident
posted on 22/12/08 at 02:50 PM Reply With Quote
This is 2nd hand info - so pinch of salt large
Apparently Sierra and Granada calipers used different handbrake pull off springs, the Grandada springs were stiffer so it was quite a common mod for Ford agents to fit Granada springs if troubles were encountered with the handbrake sticking on.
As to which is larger --- I don't know 1
[/I]
Wells
posted on 22/12/08 at 08:52 PM Reply With Quote
The way to go would have been to fit the old springs as Mark said. The problem is the company I got them from gave me £40 back for the old calipers. Guess whats still attached to them !
