Krismc
posted on 18/4/09 at 10:19 AM |
MNR wiring loom - Fan Operation
I didnt get a diagram with my wiring loom just colours marked with where to connect them, does any one know which relay, fuse and wires operate the
fan and fan switch because mine does not operate the fan when engine gets hot. i have to manually override this with switch on dash.
cheers kris
[Edited on 18/4/09 by Krismc]
GeorgeM
| posted on 18/4/09 at 10:34 AM |
snap, mine's the same, but override not working either!! Got to try to sort it this week
I don't think there is a proper schematic for the loom mnr supply, wish there was though
GeorgeM
Krismc
| posted on 19/4/09 at 04:29 PM |
Yea its a bit hard to trace on a sealed loom that uses the same colour wires on many things- and colours that change at relays and fuses.?!?
Ill let you know once i take a close look
Krismc
| posted on 31/3/11 at 02:13 PM |
Still no luck on this, fan just doesnt cut in on its own.
Anyone have a electrical wiring diagram ??
daniel mason
| posted on 31/3/11 at 02:18 PM |
Is your raditor fan temp switch working?Where have you piped it into the coolant system ? Or is it built into the radiator?
Krismc
| posted on 31/3/11 at 07:20 PM |
Rad, you got a diagram or just the dreaded list?
Id like too know which relay etc its worked off
[Edited on 31/3/11 by Krismc]
daniel mason
| posted on 31/3/11 at 07:26 PM |
the only thing i could suggest is to put everything on and disconnect relays and fuses 1 at a time! this way you will identify all that is working as
well as the one which is not!
Krismc
| posted on 4/4/11 at 07:19 PM |
I took car out on weekend and forgot too put the fan on my self, the fan kicked in automatically and cuts back of, brings the light on on the fan
overide button too let me know, and even it i turn switch on and off it stays on until temp drops and stays on with ignition off, i think i must of
had a sticky switch, i did fit the rad switch in 2006 and its never been used since, but its working now
first350
| posted on 4/4/11 at 07:27 PM |
if it stays on even w/ the ignition off, be careful it doesn't drain the battery...
iain b
| posted on 4/4/11 at 07:28 PM |
the fan will stay on until temp goes down even with key turned off
Krismc
| posted on 4/4/11 at 07:31 PM |
Thats the correct way for it to be wired, ill just have to sit at idle before i switch off, as ive only got a small battery
