Author: Subject: VortX Fuelpump placement?
Triggerhappy
posted on 18/5/09 at 04:16 PM Reply With Quote
Hi,
Where did you put your filters and pump?
Pics, preferably BEC installations.
Michael
Im from Sweden, so im escused...The Muppet drummer for president!!
Pdlewis
posted on 18/5/09 at 04:58 PM Reply With Quote
Not the best picture but i have my pump fitted behind the diff
Build Photo Album
Updated 05/02/2009
richardh
posted on 18/5/09 at 05:08 PM Reply With Quote
pump is near diff under the tank - ish
filter is in engine bay
now if i did it again then i'd filter it before the pump and then a 1 way filter valve in the engine bay
stops that annoying pump going to fill the pipe and then the filter before i can think of starting it
Time for a change!
blakep82
posted on 18/5/09 at 05:29 PM Reply With Quote
and stops crap getting in the pump too
________________________
cosmick
posted on 18/5/09 at 06:31 PM Reply With Quote
Fuel Pump Position
If you are building your car now, why don't you put a standard Suzuki fuel pump in the bottom of your tank. this will be a very good position and will allow you to use only one fuel line to the engine.
i modified mine over this winter and the result is that i now have a much neater supply and i have an accurate fuel gauge because the Suzuki pump also has a sender.
You can fit a high pressure fuel filter outside the tank immediately as the pipe comes out of the pump.
You will not need to use a pressure regulator as the pump regulates in the tank.
bassett
posted on 18/5/09 at 06:38 PM Reply With Quote
Pics in my blog below if interested. Best place i thought it would go is below the left driveshaft on the chassis rail, I made two pump sized brackets in ally strip and bolted it to the chassis. Also used chassis foam for a tighter grippy fit.
Adam
Wheels244
posted on 18/5/09 at 07:21 PM Reply With Quote
I did the same as Adam, but used rubber lined P clips
posted on 19/5/09 at 07:22 AM Reply With Quote
Mines about the same place as the one above with a filter before and another up in the engine bay.
Mine being carbs, gravity fills the pump to give it an easier time.
