Author: Subject: pushrod length
JoaoCaldeira
posted on 28/7/09 at 07:01 PM Reply With Quote
pushrod length
Hi all.
Following an old thread (here) about front stifness, I got myself thinking if I got my car right.
IIRC there were different pushrod lengths if you use the front lower wishbone up or down.
Mine are 15 inch.
Can you please measure yours? (IF your ride is fine )
Which side is your lower wishbone?
If you can, please respond urgently as I'll have a suspension setup right in the morning.
Joćo
spdpug98
posted on 28/7/09 at 07:11 PM Reply With Quote
A pic of mine:
Not sure if they help, I thought the most important thing was to have the bottom are level with the ground, I can measure tomorrow if need be
Stella pic back!!! Thats what kept me going during the build.....all my shut lines looked OK during the build!!!!!!!!
[Edited on 28/7/09 by spdpug98]
My Blog: http://spdpug98.wordpress.com/
RichardK
posted on 28/7/09 at 07:13 PM Reply With Quote
Mmmmm Stella
Gallery updated 11/01/2011
ReMan
posted on 28/7/09 at 07:39 PM Reply With Quote
Forget Guiness, Stella is good for you
GeorgeM
posted on 28/7/09 at 07:56 PM Reply With Quote
Hi Joao,
most important thing to check is that the
circlip for the upright is on the bottom of
the wishbone.. This will make sure that
it is not the circlip taking the force on a
bump!
Hopefully, this will mean that the pushrod
mount tube is on the top of the wishbone,
putting the weld under compression
instead of trying to pull it apart.
The pushrods do vary in length, but you
should be able to adjust to compensate.
Mine are 355mm and seem fine.
As said, the lower bone shoud be parallel
to the ground.
good luck
GeorgeM
JoaoCaldeira
posted on 29/7/09 at 12:41 PM Reply With Quote
Thanks everyone.
It seems my pushrods are longer 1" than yours, George.
Well... let's see how the suspension setup goes...
Joao
bassett
posted on 29/7/09 at 09:19 PM Reply With Quote
Er mine are 384 hopefully have the shorter ones with me soon so i can do the same - full set up
sucksqueezebangblow
posted on 30/7/09 at 11:29 AM Reply With Quote
Ditto, mount tubes should be on top and circlip underneath or full suspension load will be on the circlip which needless to say is bad news!
JoaoCaldeira
posted on 30/7/09 at 12:31 PM Reply With Quote
So having 384 mm ones and mount bracket on top is a no no? Or just makes it stiffer?
Joao
GeorgeM
posted on 30/7/09 at 12:44 PM Reply With Quote
Joao
rocker angle will be wrong, so springs & dampers
won't feel right. I'd replace them.
don't just check the pushrod mount though,
the circlip under is much more important. Some
were made with the circlip & tube under. With
these you will need the longer pushrods.
HTH
GeorgeM
Johneturbo
posted on 31/7/09 at 02:04 PM Reply With Quote
Joao
i know mnr made some shorter pushrods for people that turned over the wishbones, i'm sure you can send them back for shorter ones send chris an email.
the newer design wishbones have the bracket under and also the circlip under.
