cerbera
| posted on 30/1/11 at 02:25 PM |
MNR Windscreen
I'm finally getting round to fitting my new screen but it doesn't seem to want to sit naturally and I am having problems trying to find
the best fit.
Of those who have fitted a screen what dimensions have you used for the 2 fixing holes either side? If you could give me the measurements from the
front edge of the scuttle and the lower edge it would be appreciated.
Cheers in advance.
Agriv8
| posted on 1/2/11 at 07:43 AM |
Hi Cerbara.
Providing you are not 6'6" like me the bottom of the mounting brackets should be parallel the the base od the scuttle with this in mind
its just a case of moving the screen back and forward.
I have gained a few more MM on mine buy tilting the screen forward slightly so the measurements on mine will be of no use to you.
Was due to nip over and see marc tonight but a 3 week old insomniac means I had better get home a some Kip.
Have you tried emailing marc as i am sure one of the cars in the workshop has a screen fitted ?
Regards
Agriv8
cerbera
| posted on 1/2/11 at 12:19 PM |
Cheers for the reply Agriv8, will email Marc.
