Author: Subject: Cable through bulkhead
Tinks
posted on 14/8/06 at 12:20 PM Reply With Quote
What type of grommrt / cable gland have fellow builders used to prtect the wiring loom through the bulkhead
Many thanks in advance
BKLOCO
posted on 14/8/06 at 12:59 PM Reply With Quote
The big b****rd from the Sierra donor
shortie
One thing you might want to think about is not running it through the bulkhead unless you are going to put a big connector on it so that if you need to remove the bulkhead you can without cutting the loom!
I was going to do this but in the end ran it down the tunnel.
Rich.
Tinks
posted on 14/8/06 at 01:15 PM Reply With Quote
Shortie
You must have used a grommet etc through the transmission tunnel to get behind the dash
G.Man
Rich
You cut a U in the bulkhead and slot the grommet into it so you dont ahve to cut the loom of you need to remove either that or the bulkhead...
Opinions are like backsides..
Everyone has one, nobody wants to hear it and only other peoples stink!
Winston Todge
posted on 14/8/06 at 04:46 PM Reply With Quote
Are you building an MK or an MNR?
Danozeman
posted on 14/8/06 at 06:15 PM Reply With Quote
I have ran my loom under the scuttle throught the trans tunnel and up underneath it. Keeps it all neater and ju can take the scuttle off without disturbing the loom.
Dan
shortie
posted on 14/8/06 at 06:42 PM Reply With Quote
I just came up to the dash under the scuttle and ran to the front and rear along the tunnel with the fuse box behind the dash so no need to feed anything through the bulkhead\battery tray
Rich.
