JoaoCaldeira
posted on 16/3/07 at 08:25 PM |
SVA PCIII USB map (2003 R1)
Hi all.
I need a PC III USB map used (with sucess, plz ) in SVA
It will be for legalization my VortX in Portugal
Joao
chockymonster
posted on 16/3/07 at 08:43 PM |
Joao,
sent it to your msn address.
Let me know if you didn't get it.
JoaoCaldeira
posted on 17/3/07 at 07:19 AM |
Hi.
nope... can you please send it to
joao_caldeira <.at.> yahoo <.dot.> com
Thanks,
Joao
chockymonster
posted on 17/3/07 at 09:05 AM |
Trying again
JoaoCaldeira
posted on 18/3/07 at 07:34 PM |
Hi all.
Anyone else, please?
I'm failing on fast idling and I'd like to see other maps, please!!!
Thanks,
Joao
chockymonster
posted on 18/3/07 at 08:20 PM |
Joao,
what throttle percentage is your fast idle running at?
JoaoCaldeira
posted on 19/3/07 at 01:53 PM |
quote: Originally posted by chockymonster
Joao,
at 2500-3000 rpm I'm doing "-12"
Thanks again Paul,
Joao
chockymonster
posted on 19/3/07 at 02:30 PM |
That's not what I meant.
When you are doing the fast idle test leave the PCIII connected to the laptop and have the software running.
It will show you rpm and throttle position.
You can then use the throttle position information to reduce the fuel at that point, this can all be done with the engine running.
marc n
posted on 20/3/07 at 06:44 AM |
hi joao
can you send or post the exact figures you are getting then i can have a proper look at it, the one thing to remember the humidy / altitude / air
pressure is bound to be different in portugal than in the uk, hence why the original and pauls version are not quite working, its done it before so
will do it again just needs a bit of tweeking
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
