TimC
posted on 13/6/08 at 07:23 PM |
Help! Where to route bottom Radiator hose?
Hi All. I have a problem - I can't make sense of how to route a hose to the bottom of the Polo rad. It just seems impossible! Are there any
other options for the radiator?
big_wasa
posted on 13/6/08 at 07:42 PM |
I found it a pita.
helps to put the rad at an angle
mines not an Mnr
[Edited on 13/6/08 by big_wasa]
jacko
posted on 13/6/08 at 08:48 PM |
Move the rad behind the suspension and in front of the engine
TimC
posted on 13/6/08 at 09:32 PM |
Cradle in the way sadly.
posted on 13/6/08 at 09:39 PM |
2 90° bends to get to the middle and in between the shockers??
road warrior
posted on 13/6/08 at 10:46 PM |
Tim
A top hose from any Proton with a Campro engine like this.
I used these top and bottom. Just need a very slight trim on the length but otherwise perfect.
You could use a silicon 's' bend too but I had access to the Proton ones.
I'll see if I have any build pics and email them to you.
Sonja
[Edited on 13/6/08 by road warrior]
marc n
posted on 14/6/08 at 06:04 AM |
hi tim
with the cooling kit for our cars its 2 x 90s and a long alloy / stainless steel pipe pipe with a 90 degree bend on furthest end, also has the inlet
for the oil to water cooler, i will take a pic of the lower coolant pipe on my car when it comes out of the trailer this afternoon
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
TimC
posted on 14/6/08 at 06:44 AM |
Thanks all - pics would be great!
vinny1275
posted on 14/6/08 at 06:58 AM |
Hi Tim,
There's pics of this in my blog / web album - we had to take a chunk out of the rad mounting bracket, but we'll stiffen it back up once
its done...
[img]http://picasaweb.google.com/vinny1275/RubyComplete/photo#5205530975882795554[/img]
and
[img]http://picasaweb.google.com/vinny1275/RubyComplete/photo#5205530997357632050[/img]
What you can't see is the angle of the long alloy joiner, it goes up towards the driver's side of teh car, then uses a 90 degree bend to
turn down over the top of the steering rack...
HTH
Vince
ernie
posted on 14/6/08 at 09:23 AM |
I used 2 90' bends and short length 32mm copper pipe from plummer's shop
marc n
posted on 15/6/08 at 08:07 AM |
hi tim hopefully this helps explain a bit ( pic in build manual )
