markyb
posted on 16/6/08 at 10:31 PM |
MNR loom to R1 loom
I think I have got everything sorted with my bike loom (03 R1) with the necessary wires being shorted but I am not sure how to connect the MNR loom to
the bike loom.
I want to start the engine via the sierra ignition but am not sure how to connect the 'start crank position' wire on the MNR loom (red and
white cable) to the bike loom to get a spark
do I splice into a wire in the bike loom or is it connected to the engine in some way ?
Johneturbo
posted on 16/6/08 at 10:37 PM |
This may help you a little, it's an older engine thou.
http://www.freewebs.com/richiecoulson/may2006.htm
i used the bikes starter wires on a starter button.
smart51
posted on 17/6/08 at 07:19 AM |
Look at this thread for a simple picture of the 98 R1 loom. It shows my wiring in
of the ignition wire from the ignition key to the top of the start relay. You must cut the wire to the start relay from the rest of the circuit as
shown.
Otherwise, ignore the crank wire and use the starter switch as on the bike.
markyb
posted on 17/6/08 at 03:41 PM |
thanks for both the links - I thought it might be one of the wires at the start relay but wasnt sure
